Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: Installing new water pump and fan 52 8N
Kenster
10-31-2012 19:41:35
Good tip on the cardboard. Thanks for that.
I got the fan belt out of the way before I removed the fan and pump. It is a 5/8 inch belt and was only a couple years old and is in good shape. I was wondering about using gasket grease and have a tube... pump side only!
I hope I don't have to replace the studs. I've heard of someone having to do that but most have reported it was not necessary. I'm not sure how to even do that.
Still would like advise on whether to join the fan to the pump BEFORE installation or install them separately. Bolting the fan to the pump before installing seems like it would be a lot easier.
Dean
10-31-2012 20:20:20
 Re: Installing new water pump and fan 52 8N in reply to Kenster, 10-31-2012 19:41:35
It makes little difference if the fan is attached to the pump IF the radiator is removed, which is a very small job with the hood already removed.
With the radiator in place you will have difficulty getting the fan onto the pump OR the pump onto the studs.
Just remove the radiator to make things simple.
Dean
