Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: OT-Collective knowledge needed....
[Return to Forum]
dbNga
10-31-2012 08:48:10
205.174.22.27
While trying to put my '50 model 8N in the garage, the door stopped about waist high. I can dis connect from opener system and push up manually without too much effort, the motor will retract the trolley if disconnected from door, but the motor refuses to raise door completely even if I am pushing up on door to help. I have tried tweaking the adjustments on the motor but no improvement is reached. What should I do next or does anyone know of a forum such as this one I can go to? Thx.
[Reply]   [No Email]
BillM (OH)
10-31-2012 22:16:37
173.81.81.180
Re: OT-Collective knowledge needed.... in reply to dbNga, 10-31-2012 08:48:10
I just replaced the drive sprocket on mine - big nylon? gear
was all eaten up - new one works fine. Got the part from
someplace up in Ontario, NY (Just google your make + parts).
IIRC it cost a whopping $27 or so. You have to remove the
cover to get to it.
  [Reply]  [No Email]
Brad Buchanan
10-31-2012 18:47:31
74.71.185.165
Whatever you do cut the power before working on the drive system.
There are small switches in the drive and if you hit one you could get your hand caught and have it run between the sprocket and chain.
Don't ask me how I know that.
Brad
  [Reply]  [No Email]
Robert Work
10-31-2012 16:29:37
184.3.94.123
Try spraying some PB Blaster (or whatever you have on hand) on the rail where the trolley is sitting. Could be nothing more than a lack of lubricant on the rail.
  [Reply]  [No Email]
don t-9n180179
10-31-2012 10:14:42
63.73.199.69
Sounds similar to mine when I had a broken door spring.
  [Reply]  [No Email]
Roger in Iowa
10-31-2012 09:07:00
166.182.3.230
Is the rail for the trolly two piece. Had trouble with mine last week. The splice in the rail was loose and mis-aligned. Had to straighten and tighten. Trolley stopped at the splice.
  [Reply]  [No Email]
old
10-31-2012 08:54:46
209.86.226.56
Carefully hold the chain or what ever the motor uses to pull and the door and make sure you can not hold it back. If you can the motor is going bad and is weak. Reason I say carefully if it pulls to hard it can cause you to get hurt. Also if you do that listen for something slipping etc. Been to many years since I worked for a place that had a lot of those type doors that we fixed all the time
  [Reply]  [No Email]
ARCO petee
10-31-2012 08:59:03
216.251.160.21
Re: OT-Collective knowledge needed.... in reply to old, 10-31-2012 08:54:46
At least ware leather gloves. Might want to check to see the trolly was properly enguaged.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
