Topic: Two 8n questions
[Return to Forum]
| Author |
[Modern View]
| toddo
10-30-2012 06:55:40
70.41.162.59
Greetings,
Long time lurker, first time poster.
Picked up a nice 8N last week( ex wife ended up with my old one). Seems to only have one problem (fingers crossed).
When I press the starter it engages, then typically cuts out making a high pitched "Whirring" noise.
-Do I have a bad starter?
-If so, would a rebuild kit fix or do I need a new one?
-Or is it something else?
Know this is probably a simple fix but I've got zilch for mechanical knowledge and ability. Didn't buy manual yet either.
SECOND: Seller just changed oil and used Shell Rotella 15W40. Any problem with that? (fwiw, I'm in central PA).
Any feedback would be greatly appreciated!
Toddo
This post was edited by toddo at 06:57:15 10/30/12. |
[Reply] [No Email] | |
| toddo
10-30-2012 09:11:50
70.41.162.59
Re: Two 8n questions in reply to toddo, 10-30-2012 06:55:40
| Wow, you guys are quick, thanks for the input.
Glad to hear the oil should be okay, I thought non-detergent oils were best in this case.
Re the starting issue, 6V, front mount distributor, sorry.
New distributor, tractor seems to run just dandy when it starts. BTW, didn't do a compression check but no smoke, no bad engine noises. Sweet.
Think I'll:
1) Change the battery, can't find any punch date sticker and don't have a 6V charger yet but sure can't hurt. Gonna try a red-top Optima.
2) If no cure, will clean the shaft as suggested, Bruce thanks for #36.
3) If no cure, will proceed with other suggestions. Gotta buy manual. Have a great neighbor next door (who had six show tractors) in case I need a hand.
My lane is about 3/8 mile, gonna find a blade and get ready for snow.
Thanks again for all the input. Any more just fire away!
Toddo |
| Dell (WA)
10-30-2012 09:41:03
71.217.27.231
Re: Two 8n questions in reply to toddo, 10-30-2012 09:11:50
| | toddo........starter bendix drive must be SQUEEKY CLEAN. I use spray BRAKE cleaner. 2nd thing, yer starter must be GROUNDED. Remove the 8" bolts and pull the starter out about 1/2". Now WIRE BRUSH the H3LL outta the gap. Now re-install the 8" bolts. Simple, eh? Would it surprize you to learn that Ford spec'd 30wt DETERGENT oil in 1939??? Synthetic oil is also highly detergent. .........oily Dell |
| old
10-30-2012 08:45:45
209.86.226.57
| 6 or 12 volts that can help us help you. Front or side mount distributor?? That to is info needed. If the timing is off that can happen as can the spark being poor. Low compression can also be an issues that can cause things like that |
| glenn ma.
10-30-2012 08:29:53
76.24.110.24
| Charge the battery, Mine will do the same thing when low |
| soundguy
10-30-2012 08:04:59
184.4.146.28
| | ditto what bruce said. the starter drive kicked out. the odler drives do that.. especially if the engine coughs once and don't start. clean up the drive and do a tune up. if she still does it and bat cables are good and she spins fine but kicks out.. repalce with a new followthru drive.. |
| Bruce (VA)
10-30-2012 07:04:51
24.125.80.178
| | "When I press the starter it engages, then typically cuts out making a high pitched "Whirring" noise." The noise is the starter spinning after the bendix prematurely disengages. You can pull the starter, check the shaft & clean it up (no lube). If that doesn't work, pull the starter (see tip # 36) & replace the bendix. " Seller just changed oil and used Shell Rotella 15W40. Any problem with that? (fwiw, I'm in central PA)."
The oil is fine. |
| oldtanker
10-30-2012 07:03:53
66.228.255.239
| HI, welcome to the board.
Sounds like the starter drive is going bad and disengaging too. You can replace that yourself. 15-40 should be good unless you get real cold and are going to use it in the cold.
Rick |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
