TractorLinks.com
Show Parts for Model:
Will charge no more.
Richard from SE AZ
10-29-2012 22:00:01
I have tried to keep everything working on my 2N the way it should. But,I have never been able to get the cutout to release so I have made it a habit to disconnect the battery after using the machine.Well, I got distracted by a strong wind that came up and in my hurry to shut the shop doors I forgot to take off the battery cable. Now it won't charge. Any ideas as to what I burned up?
soundguy
10-30-2012 06:06:19
 Re: Will charge no more. in reply to Richard from SE AZ, 10-29-2012 22:00:01
i agree with jmor.. check the cutout.. it may have finally opened for you :)
If it is the cutout.. gut it and hit radio shack and buy a 25a full wave bridge and wire in one of the segemnts across the arm / bat terminals on the cutout.
for positive ground.. that means gen provides (-).. thus the diode symbols need to be wired a specific way.
one side has a flat line, the other a triangle.
wire the flat line side to arm, and the triangle side to bat.
it's good for 25a which is mor ethan 2x what your genny can make.. and it's got 3 built in spares IF that segment ever gives out.
or you could parallel a set of segments and have 50a capacity.. :), and a spare..
JMOR
10-29-2012 22:11:15
 Re: Will charge no more. in reply to old, 10-29-2012 22:00:01
Quoting Removed, click Modern View to seeNot a lot of possibilities there..........cut out or generator.
Jumper across cut out & see if it charges.........if not generator is likely...unless some wiring/connections burned up.
