Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 9N Parts Online
Re: 9N will not crank
10-29-2012 20:00:45
No solenoid as on 8N, just a mechanical switch operated by button/hinge/push rod as seen here. If power actually to terminal on starter motor, then switch must be working. Then check motor housing to ground (rust/paint/corrosion at mating surface to engine) and whack it with hammer with power applied to disturb stuck or worn out brushes. Also check loose cable connections or dirty connections or bad cables(usually at terminal ends).
