| Ford 9N, 2N & 8N Discussion Forum |
Topic: 9N will not crank
[Return to Forum]
| Author |
[Modern View]
| Rlpintx
10-29-2012 19:43:38
71.113.246.28
I went out to help brother in law with his 9n that he wanted to load. I don't have a manual handy and forgot that 9Ns or a bit different than 8ns. It has been converted to 12 volt and it is getting power to the starter but the starter is doing nothing. Thinking its the plunger switch or the starter itself but it was rebuilt a year ago maybe a little more. Can someone remind me how the starting systems are different and give me some tips on what to check to get this thing to start again. We did get it to start by pulling it and it runs just fine. |
| soundguy
10-30-2012 06:23:54
184.246.191.76
Re: 9N will not crank in reply to Rlpintx, 10-29-2012 19:43:38
| | ditto what the others said. the plunger on the trans top merely presses a switch via linkage. that is just a high current start switch. like crowbaring across the contacts. if the starter is in fact getting power.. and not spinning.. check starter, bat cables, bat or contacts. |
| old
10-29-2012 21:40:17
209.86.226.34
| If it is in fact getting power to the starter and the starter does not spin then you either have a weak battery a poor starter ground or a bad starter plain and simple. |
| JMOR
10-29-2012 20:00:45
72.181.173.171
Re: 9N will not crank in reply to TheOldHokie, 10-29-2012 19:43:38
| No solenoid as on 8N, just a mechanical switch operated by button/hinge/push rod as seen here. If power actually to terminal on starter motor, then switch must be working. Then check motor housing to ground (rust/paint/corrosion at mating surface to engine) and whack it with hammer with power applied to disturb stuck or worn out brushes. Also check loose cable connections or dirty connections or bad cables(usually at terminal ends).
| Royse
10-29-2012 19:55:16
69.36.49.151
Re: 9N will not crank in reply to Jerry/MT, 10-29-2012 19:43:38
| The 9N, if they used the original neutral safety push switch when they converted
it to 12 volts, has a mechanical push button switch as opposed to a solenoid.
If you are getting power to the lug on top of the starter, that is at least making contact.
If it is in fact battery voltage at the starter lug, not something less, I would
look for a bad ground to the starter.
You could try grounding the starter case to the frame with one lead of a pair of
jumper cables and see if it will crank normally then.
Bad connections are a major culprit. Both ends of each battery cable, the area
where the starter case meets the bell housing, etc.
If you have battery voltage to the starter, and ground it and it still won't crank
I would have the starter tested. |
| Rlpintx
10-29-2012 19:53:20
71.113.246.28
|  Picture |
| Rlpintx
10-29-2012 19:56:06
71.113.246.28
Re: 9N will not crank in reply to Rlpintx, 10-29-2012 19:53:20
|  Picture |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
