Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: 8n pulling 30 amps at 1/2 throttle no load
JMOR
10-29-2012 17:40:09
Quoting Removed, click Modern View to seeOK, my bad. I mis-read your sentence. Yes, gen field is a direct wire to VR field terminal. It does however sound like field contacts in VR are stuck closed, thus grounding the generator Field terminal all the time & that yields full field current & max gen output. BUT, a bad or even undercharged battery will have a low enough voltage to cause the field control to call for full charge until battery voltage rises to a level that VR senses that voltage & starts to reduce field current. Can you get a good battery voltage measurement both before starting and after/while running at 30amps?
ToddNick
10-29-2012 17:50:40
 Re: 8n pulling 30 amps at 1/2 throttle no load in reply to JMOR, 10-29-2012 17:40:09
Battery shows 6.08 standing (post to post) and climbed to 7.3 after running mid throttle for a few minutes.
Copyright © 1997-2015 Yesterday's Tractor Co.
