TractorLinks.com
Show Parts for Model:
Re: 1950 Farmall Tractor C model Revese Stuck
old
10-28-2012 16:22:15
LOL the only problem you have is between your ears and not understanding the way a diff. works. If you jack up most any rear wheel drive machine and spin one tire froward if in park or gear the other wheel will turn the opposite way and if it did not you would have a problem. 2nd gear is to low a gear to pull a tractor in to start it and 15 MPH if the engine did spin over would be way over the RPM limit of the engine and you could well throw A rod out the side of the block doing that. Top speed on that tractor wide open in 2nd gear might be 5 MPH so you got lucky that you did not brake parts
