Topic: Re: 1950 Farmall Tractor C model Revese Stuck
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Royse
10-28-2012 15:51:28
69.36.49.151
Transmission is probably fine, tires spinning backwards when attempting to pull is pretty common.
If you try to pull start it, you should try in the highest gear reasonably possible.
If it has sat that long there are some things I would do before trying to start it.
Take the spark plugs out and pour the cylinders full of transmission fluid and let
it soak a few days to loosen up the rings. Put the plugs back in to keep junk out.
After a few days take the plugs out and roll it over to blow any remaining ATF out.
Drain the old gas and replace with new.
Make sure you have gas flowing to and through the carb by taking the plug out of the bottom.
Clean and re-gap the points.
Charge or replace the battery. If your C has a magneto it will start without the battery
but if it has a coil/distributor ignition, it still needs battery power to start.
Folks over on the Farmall board may have more specific information on that model.
Good luck! :) |
[Reply] [No Email] | |
10-29-2012 14:17:37
107.199.149.239
Re: 1950 Farmall Tractor C model Revese Stuck in reply to Royse, 10-28-2012 15:51:28
| Thanks for your input. Another thing that was crazy was I went to jump start the tractor today and the red cable went to the POS and the black went to the NEG. Only prob is that the Red cable is hooked to the frame and the black is hooked to the starter. I beleive this tractor is a 6V system. I think the cables are reversed for some reason. Shouldn't the red be on the starter and black be on the frame? Someone painted them incorrectly I assume. Is it safe to hook my POS jumper cable to the starter and the NEG to the frame and try to start after I do the other things you said? Also, about the tires spinning backwards. After the fisrt run, the right tire wouldn't budge when the clutch was released. It just skidded. I am not mechanical, but just want my tractor to run again. I have been deployed to Afghanistan and haven't been donig proper maint the past year or two. Thanks for your time. |
| 55deere70
10-29-2012 18:16:27
75.138.191.254
Re: 1950 Farmall Tractor C model Revese Stuck in reply to Re: 1950 Farmall Tractor, 10-29-2012 14:17:37
| Your farmall C is 6V positive ground. Nothing crazy or unusual about that. Next time you want to pull start your tractor, put it in 4th gear, get it rolling and let the clutch out, please be careful. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
