TractorLinks.com
Show Parts for Model:
Re: How to flush the head?
DON TX
10-28-2012 11:51:21
Not sure I follow. What valve and pump handle?
DON TX
Britcheflee
10-28-2012 11:57:14
 Re: How to flush the head? in reply to DON TX, 10-28-2012 11:51:21
Well, I think he was making a bit of a joke - different kind of head....do you think that the same stuff you use to do a radiator flush might work?
I somewhat doubt CLR would do much - probably need some industrial strength stuff to shift that - then there is the risk of loose gunk getting into the water pump and jamming that up. Good luck.
Lee
DON TX
10-28-2012 12:08:29
 Re: How to flush the head? in reply to Britcheflee, 10-28-2012 11:57:14
I had a feeling it was a funny, but I guess it went over my head. (Pun intended). The thought occurred it could just move to another spot. Since the pump is off I hope it would flush out. The radiator flush from Prestone uses sodium citrate and says it isn't acidic. CLR says not to get it on your flesh so I figure it might be stronger. Could be wrong. I'm leaning toward muriatic acid but would water it down. DON TX
