Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: follow for Bruce (VA) and old
Ken(Ark)
10-27-2012 17:56:02
EI is a luxury item . EI comes with a higher price tag and if it should fail then it is usually a total loss .
EI is not a magic cure all but it is a nice luxury if that's what a man wants . It can cut down on maintenance since it does not need routine inspection , it may help smooth out a rough idle , is more forgiving on a loose shaft or worn lobes , and does not work out of adjustment .
30 years ago I smoked a Mallory Unilite while jump starting my pick up :(
Make sure your battery and charging system is working properly . A bad alternator spike could be trouble .
Personally I would recommend to buy and rebuild a used dizzy to keep on the shelf . Points or EI usually fail when you really need your tractor .
old
10-27-2012 18:11:10
 Re: follow for Bruce (VA) and old in reply to Ken(Ark), 10-27-2012 17:56:02
I do it the easy way I keep a couple extra back up tractors that way if I need to get it done I have a back up for the one that is being a pain most of the time
