Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Whining spool valve.
[Show Entire Topic]  [Return to Forum]
ZANE
10-27-2012 17:45:50
98.83.22.30
Bad cylinder or hose. I've seen hoses have the inside lining collapse and completely restrict the flow of oil. But if you can't move the cylinder with both hoses off it's got to be the cylinder
Zane
[Reply]   [No Email]
ARCO petee
10-27-2012 18:04:30
71.32.188.145
 Re: Whining spool valve. in reply to ZANE, 10-27-2012 17:45:50
This is exactly the reason I pulled the lines off. My dad had a suburban years ago that if the brakes were used moderately the steering wheel would take all the shoulder strength a guy could muster to hold course. Took a long d
Darn time to figure out that one of the front break hoses had seperated internally. It was like a new truck with new hoses.
If I had not pulled the rod with all my might I would have a fresh set of hoses on now.
I appreciate all the thoughts and hints guys I'm green on engines and barely a sprout with hydraulics.
[Reply]  [No Email]
ZANE
10-28-2012 07:22:31
98.83.100.116
 Re: Whining spool valve. in reply to ARCO petee, 10-27-2012 18:04:30
This really has nothing to do with your problem, but a couple of weeks ago I was putting a really old big Ford loader on a friends 3000 Ford tractor and one of the bucket cylinders had the hoses off for years and water had collected in it and lived there for years so I decided to take it apart to see if I could free it up and hone it etc and save a lot of money for my friend.
I decided to tie it to a big poplar tree with my big 3/8" logging chain and use my old Ford F600 with it's 10,000 pound winch to pull it apart after the end cap was removed. On the first try the old 5/8" cable on the winch parted. I cut off about 10' and then with two heavy snatch blocks I started pulling on the cylinder again and the truck started moving, dragging the chained chocks along with about 6" of sod and dirt. I then tied the heavy pipe front bumper to a Pecan tree about 1' in diameter and started pulling again with the three part cable set up. The rod moved out about an inch and when it did lots of the leaves of the Pecan tree fell off and rained down on the front of the truck. Gritted my teeth and let it keep on pulling. My dog Hobo was behind the big Poplar tree watching me when with a loud bang my 3/8" log chain broke and swung around the tree almost hitting Hobo. He was a blurr going around the shed last time I saw him that day!
The cylinder is lying on the ground beside my shop and one day I am going to try it again and use a Rose budd while pulling to see if can get it apart.
If I had some Nitroglycerin I'd pour some in the port and set it off with a remote device with it about a mile away with it burried in a hole about 10' deep and see if that would get it apart????
I bought a cheap cylinder from Surplus center and finally got the loader fixed and delivered. I made $250 for about a weeks work. I'm doing good!
Hope you have better luck with your cylinder.
Zane
[Reply]  [No Email]
ARCO petee
10-28-2012 14:15:40
216.161.135.14
 Re: Whining spool valve. in reply to ZANE, 10-28-2012 07:22:31
Great story,
I went mostly the same way. I had just drained the cylinder and didn't want to fill it again since it made a mess the first time. I hooked it to the loader and chained it to my Chevy van. Nearly pulled the ford all the way down the driveway with the park brake on in 1 st gear and the back blade down. Eventually I got the cou
[Reply]  [No Email]
ARCO petee
10-28-2012 16:08:46
65.102.111.219
 Re: Whining spool valve. in reply to ARCO petee, 10-28-2012 14:15:40
Darn phone
Any way I got the couple inches I needed to pop the ram apart. The rod was kinked and the cylinder was worn hugely. A testiment to the power of hydraulics.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
