skyhiranger
I searched, but didn't come up with an answer.
'51 8N
How are you supposed to install the valve guides without tearing the seals?
There is a small sharp ridge all the way around the the top of the valve guide bore, so there is no way to install the valve guide from the top without the seal catching on the lip and getting damaged.
Do I need to grind the lip of this ridge down?
I took some pics, to try to show the ridge. I'll see if I can post them.
In the first pic, you can see the ridge a little better in the one off to the right.
'51 8N
