Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Lack of cranking power
[Return to Forum]
jmead9
10-27-2012 12:43:38
209.74.116.166
This is perhaps going to sound like a stupid
question, but nevertheless I am stumped. On my
1950 6V 8N (side-mount distributor), I don't seem
to have any cranking power. I have a brand new
Interstate 6V battery (purchased on 8/8/12). After
having this problem, I took the battery back to
the place of purchase and had it tested. It tested
just fine and it was fully charged. I cleaned the
posts and cables and still have the problem. I do
not seem to be able to find any loose connections.
After putting the battery back in, it rolled the
tractor over for maybe 10 seconds (very slowly and
not enough 'umph' to start it) and then did not
have enough power to turn it at all. I am looking
for suggestions.
[Reply]   [No Email]
Bruce (VA)
10-27-2012 14:49:40
24.125.80.178
 Re: Lack of cranking power in reply to jmead9, 10-27-2012 12:43:38
There are 4 likely causes of your problem:
1. A weak battery (charge it & check it per tip # 49))
2. Dirty grounds/connections (remove the cables & clean the connections)
3. Bad cables or incorrect sized cables (replace them - see tip # 41)
4. Bad ground between the starter & the block. (pull the starter away from the block & clean the mating area - see tip # 36)
You have addressed the first two likely causes.
Another cause to consider after you eliminate the four most likely is a bad starter as Dean suggested.
[Reply]  [No Email]
Dean
10-27-2012 13:53:49
67.172.15.77
What size (AWG) are the battery cables?
Do you have an OEM starter (rebuilt or otherwise) or an inexpensive aftermarket one?
Dean
[Reply]  [No Email]
soundguy
10-27-2012 12:59:33
184.233.209.16
ditto.. check the palce the battery cable grounds too. also pull the starter back about 1" and polish the surface so that it gets good connection.
soundguy
[Reply]  [No Email]
Dell (WA)
10-27-2012 12:54:46
63.226.218.162
jmead9........GROUNDS are the BIGGEST problems with 6-volt systems. Sounds like you need to re-ground the back end of yer starter motor. Just remove the 8" screws and slip the starter motor out about 1/2" and WIRE-WHEEL the H3LL outta the gap. Now re-install yer 8" screws and try that with yer better grounded starter motor.........the grounded Dell
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
