Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Whining spool valve.
old
10-27-2012 10:42:27
Sounds like the cylinder piston rod is bent which can happen if the engineering of the bucket cylinder was poorly done. Once that rod gets bent it will lock the cylinder up so you can not extend it with hyds and can be a real bear to ever extend with out taking the cylinder apart and even then can be very hard to do
ARCO petee
10-27-2012 11:46:41
 Re: Whining spool valve. in reply to old, 10-27-2012 10:42:27
Nice call
I've seen cooked spaghetti noodles that hold their shape better than that rod. Can a shop straighten that or do I need a new one.
Then to figure out why it bent.
ARCO petee
10-27-2012 12:00:02
 Re: Whining spool valve. in reply to ARCO petee, 10-27-2012 11:46:41
Never mind. Just answered my own question. Looks like a bow can be fixed. This is a kink so I guess I'll go shopping for a 18" x 3" bore double acting super duper pooper scooper.
old
10-27-2012 12:59:46
 Re: Whining spool valve. in reply to ARCO petee, 10-27-2012 12:00:02
Pretty common size cylinder I probably have 3 plus of them laying around but then I do have a good number of them on hand. Before I would even think about putting another one on I would look things over extra good to see where it hangs up and causes it to bend. I have snapped those rod in to because of not having the correct cylinder or poor engineering
ARCO petee
10-27-2012 14:42:05
 Re: Whining spool valve. in reply to old, 10-27-2012 12:59:46
It was whining when I got the tractor I know the PO was digging ditches in sandy loam with the 6 foot snow bucket on. I'm hopeful the extra forces in pushing that huge amount o soil did the rod in. I've already checked to be sure neither the rod or case make contact with the loader frame beyond that I'm not sure what besides abuse would bend the rod. Open to hints.
old
10-27-2012 17:12:52
 Re: Whining spool valve. in reply to ARCO petee, 10-27-2012 14:42:05
As long as the cylinder misses any part of the bucket loader etc and does not bind at any of the pivot points then yes could have been caused by doing things the wrong way
Copyright © 1997-2015 Yesterday's Tractor Co.
