Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: OT: Toyota Fuel Pump Question
[Return to Forum]
Beoni
10-25-2012 08:09:08
204.89.74.135
I have a '92 Toyota truck with a 4 cylinder that's my kick around farm truck. It doesn't get driven much. It has the in-tank fuel pump. I started having problems with it taking longer to crank sometimes and not having power. Sometimes it won't even idle. When it's acting up a spray of ether will make it run which makes me think its a fuel issue. I changed the fuel filter, but no improvement. An after market pump is $135 plus $15 for the strainer/sock. Has anyone had luck in the circumstance just changing or cleaning the pump strainer/sock. I'm hoping to drop the tank this weekend, but hate spending all that money on something I don't drive every day.
[Reply]   [No Email]
Hobo,NC
10-25-2012 18:55:25
98.17.83.23
 Re: OT: Toyota Fuel Pump Question in reply to 36 coupe, 10-25-2012 08:09:08
They are about as difficult as they come to diagnosis...Most all of'em I see are worn slap arse out,,, They were not that good of a truck to start off with.... Guessing will not get'er done... its not unusual to have multiple issues... If its not worth a pump and what ever issue arises after have it ground up into sausage....
[Reply]  [No Email]
jhill52
10-25-2012 11:48:11
66.188.17.174
 Re: OT: Toyota Fuel Pump Question in reply to Beoni, 10-25-2012 08:09:08
It might also be a bad pressure
regulator.
[Reply]  [No Email]
Britcheflee
10-25-2012 08:17:35
67.187.170.181
Can you remove the fuel line to the carb and see if the pump is moving a decent flow of gas? Either by cranking or does it work just by turning on the ignition? If you are getting gas then it might be moisture in the fuel? I have a terrible problem every year with equipment/trucks which have been running ok when the weather is dry and then when it turns cold and damp they dont want to run properly or at all.
lee
[Reply]  [No Email]
Beoni
10-25-2012 08:24:56
204.89.74.135
 Re: OT: Toyota Fuel Pump Question in reply to Britcheflee, 10-25-2012 08:17:35
It's electronic fuel injection. I think there's fuel being pumped but not enough. I let it get really low on gas and added some fresh fuel along with seafoam, etc. but it didn't make a change.
[Reply]  [No Email]
old
10-25-2012 08:53:45
209.86.226.34
 Re: OT: Toyota Fuel Pump Question in reply to Beoni, 10-25-2012 08:24:56
A weak pump will cause that but you have to check pressure at the pump side of the filter to be sure it is a pump problem. I do not remember the numbers but if my memory is right you need 50 plus PSI or the fuel injection system will starve for fuel
[Reply]  [No Email]
Beoni
10-25-2012 09:07:54
204.89.74.135
 Re: OT: Toyota Fuel Pump Question in reply to old, 10-25-2012 08:53:45
I'm thinking that's what it is, but I don't have anything to measure the pressure. I had a similar problem on the truck about 10 years ago. It would starve for fuel on the highway. the strainer sock had a bunch of cellulose carbon looking stuff in it. I changed the pump and sock back then.
[Reply]  [No Email]
old
10-25-2012 09:22:32
209.86.226.18
 Re: OT: Toyota Fuel Pump Question in reply to Beoni, 10-25-2012 09:07:54
Ya and the only way to know for sure is to either test the pressure or replace the pump etc. Either way you go it is not super easy to do and if the tank is close to full it is 10 times harder to do
[Reply]  [No Email]
ASEguy
10-25-2012 17:00:39
68.186.162.134
 Re: OT: Toyota Fuel Pump Question in reply to old, 10-25-2012 09:22:32
Most in the tank pumps I've done were in mostly full tanks. Murphy's law.
[Reply]  [No Email]
old
10-25-2012 19:04:51
209.86.226.11
 Re: OT: Toyota Fuel Pump Question in reply to ASEguy, 10-25-2012 17:00:39
Yep me also so you either figure out how to drain them or you drop them then pump out the gas so to make it easy to put them back in. Back in the day I could drop a transmission with out a transmission jack but now days that is not going to happen. I still remember dropping a VW engine with no jack. Crawled under it and let it sit on my chest and then slide out from under it
[Reply]  [No Email]
504
10-25-2012 20:29:36
199.127.54.155
 Re: OT: Toyota Fuel Pump Question in reply to old, 10-25-2012 19:04:51
You might want to just take the bed off the truck, if the bolts will come out ,it is a lot faster than taking the tank down. I used the cherry picker and the tie downs in the corner of the bed to take mine off.(1989)
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
