2N running fast
TSWolf
Brought this up a couple months ago, and just now had time to do some work on it. My 2N starts and runs, but revs extremely high when started. I pulled off and inspected the governor, no problems, rebuilt the carb, with no result, and did a complete tune up(plugs, points, condenser, rotor), also with no result. What else could be causing this?
Got the throttle to gov and gov to carb rods
backwards? Got preload on the gov spring? What
happens when you disconnect the rod to the carb and
control the carb by hand?
No matter what I do to the carb, whether adjusting or moving linkage by hand, it still runs extremely fast.
So your saying if you try to slow the engine down by pulling on the carb/gov rod it does not slow down?? If that is true did you maybe remove the throttle plate from the carb and install it back wards so it does not move and close up as it should???
My 9N does the same thing, but not extremely fast, but doesn't idle down by itself or stay there when put there by hand. I think I have a governor problem (?). Haven't had time to look at it to be sure, lots of dirt/grease around the thing. This is a work tractor that stays attached to a manure spreader so it doesn't stay as clean as I would like.
What should I be checking?
(quoted from post at 19:22:20 10/23/12) So your saying if you try to slow the engine down by pulling on the carb/gov rod it does not slow down?? If that is true did you maybe remove the throttle plate from the carb and install it back wards so it does not move and close up as it should???
I put everything back in as it was, but I can check.
Make sure that the idle adjustment screw on the linkage is backed off to the point it should be for slow idle and that the linkage does not bind when pushed to idle
(quoted from post at 13:07:59 10/23/12) No matter what I do to the carb, whether adjusting or moving linkage by hand, it still runs extremely fast.
b:7186348ff9][i:7186348ff9]
TSW;
Do you have the SAME symptoms, with BOTH yer carbs????
Would like to talk with you about yer problem, BUT......you will have to email me and I can give you my PHO.# via email reply!!!
My email is open, on the Modern side of this forum, at the bottom of this reply....just poke the email button, and fill in the blanks!!!!
Yer dime....but will only cost ya a pho. call!!!!
Just remember.....ya been fightin' this thing, for about two Mos.!!!! 15 mins on the phone, might fix yer problem!!!!???????
Gary :roll: [/i:7186348ff9][/b:7186348ff9]
(quoted from post at 15:31:15 10/24/12) Ok, thank you, I will be sending you an email.
b:2ae0f42758][i:2ae0f42758]
TW;
Got the email, and replied with my pho#.
Any time tomorrow afternoon, is fine for me!!
Gary :) [/i:2ae0f42758][/b:2ae0f42758]
