TractorLinks.com
Show Parts for Model:
Re: will not spin over.
Dell (WA)
10-22-2012 20:29:03
thom........you answer........"Positive and negative post of the battery, should it have continuity?"........HOW do you measure continuity? With an OHM-meter??? More better you use VOLT-meter. That is what they are made for. Iff'n I remember my chemistry correctly, each lead-acid cell is approximately 2.5-ohms. So fer 6-cell 12V-battery, I'll let you do the math. (hint: 15-ohms)
You answer......."meaning 2 flathead screws to starter. not only the power supply.".......would it surprize you to learn the 8N roundcan starter solenoid is held on by 2-ea 10-32x3/8" filister head screws. (tall flathead screw with washer) ..........HTH, mindless Dell
