Has anybody had a cam reground ?
Ken(Ark)
I don't think many machine shops are equipped to regrind camshafts . I think a flat tappet cam needs to be rehardened after regrinding ???
If anybody has had a cam reground I would love to know more details .
Location ? Cost ? Stock lift or more ?
Even if it one of the big boys that does regrinds , it would be nice for us members to know who offers this service , Thanks in Advance - Ken(Ark)
(quoted from post at 12:07:20 10/22/12) I don't think many machine shops are equipped to regrind camshafts . I think a flat tappet cam needs to be rehardened after regrinding ???
RC Automotive/Chambers Cams which is in Alexandria, VA. reground the camshaft and line bored the block for camshaft bearings in my TR4 many years ago and I would expect they still provide that service. AFAIK as long as the camshaft has the meat for it Roy Chambers will grind anything you want in the way of lift and timing. He does a lot of performance work for the Roger Ramjet racer types in this area :shock: Google turned up many other shops around teh country.
Dan
(quoted from post at 20:07:20 10/22/12) I don't think many machine shops are equipped to regrind camshafts . I think a flat tappet cam needs to be rehardened after regrinding ???
Dan (Rustbucket Dan) had a N shaft reground maybe you can find the info in the archives...
http://ytforums.ytmag.com/profile.php?mode=viewprofile&u=15436
I did not find any numbers but I am in no hurry . I did find this great advise in the archives , it is on the internet so I know it's true .
[b:f30dae3975]Paul K in IL
07-07-2005 18:14:09
136.182.2.221
Re: Cam shaft , 07-07-2005 05:05:05
If you are thinking about getting it reground, DON'T. These engines have no camshaft bearings so any metal they remove will cause increased clearance with the engine block and lower oil pressure.[/b:f30dae3975]
(quoted from post at 17:08:52 10/22/12)
[b:61e9d5e81d]Paul K in IL
07-07-2005 18:14:09
136.182.2.221
If you are thinking about getting it reground, DON'T. These engines have no camshaft bearings so any metal they remove will cause increased clearance with the engine block and lower oil pressure.[/b:61e9d5e81d]
Truly profound advice :roll:
TOH
(quoted from post at 18:51:40 10/22/12)
[b:302726e6e0]Paul K in IL
07-07-2005 18:14:09
136.182.2.221
If you are thinking about getting it reground, DON'T. These engines have no camshaft bearings so any metal they remove will cause increased clearance with the engine block and lower oil pressure.[/b:302726e6e0]
TOH
nless you deposited more metal on the lobes before regrinding, and didn't have adjustable lifters, you have a real problem don't you?
(quoted from post at 19:47:35 10/22/12)
[b:f77504b5b1]Paul K in IL
07-07-2005 18:14:09
136.182.2.221
If you are thinking about getting it reground, DON'T. These engines have no camshaft bearings so any metal they remove will cause increased clearance with the engine block and lower oil pressure.[/b:f77504b5b1]
TOH
I wouldn't call it a "real problem" but you do have to be aware of the issue. Heck even a new cam or new valves pose a problem if you are sticking with those archaic non-adjustable lifters. Since I was replacing [u:f77504b5b1]everthying[/u:f77504b5b1] none of that was an issue for me.
I never measured the lobes on the regrind I purchased but my assumption was they had been reduced. And even if I had measured them I have no specification to compare against. I did measure the journals and they were stock. FWIW both the journals and the lobes had been nitrided. Not sure how much that may have added dimensionally or how long it remains on the surface once you fire it up. I think it is sacraficial and dissipates rapidly.
TOH
PS> For a production shop churning out lots of regrinds for many different engines I would imagine build-up with a metal spray would be child's play.
search online for delta camshaft. they are located outside of seattle. they do excellent work. they have a very good website and have videos explaining everything they do.
(quoted from post at 21:04:54 10/22/12) search online for delta camshaft. they are located outside of seattle. they do excellent work. they have a very good website and have videos explaining everything they do.
I did a quick search for a local cam regrinding shop . I have sent them an email and would gladly stop by and chat if the door is opened . If I get any info I will post it .
The company claims it is "The Largest and Oldest Camshaft Remanufacturer on the Planet! "
[i:6868bf9139]Chrome Plating is a vital part of Hillcrest Camshaft's operations. Original dimensions are restored every day with our 5 in-house chrome plating tanks. We have the ability to plate and machine camshafts up to 14 feet in length. Chrome plating actually adds hardness, resists abrasions and reduces friction, therefore, increasing engine RPMs and horsepower. The chrome plating process means longer life for journals and bearing surfaces.[/i:6868bf9139]
Hillcrest Camshaft Service, Inc.
5502 West 65th Street
Little Rock, AR 72209
1-800-832-4859
http://hillcrestcamshaft.com/index.htm
Check out Effingham Regrinding, Inc. Effingahm, -IL 217-342-4186. In business since 1943....check out www.effingham-regrinding.com
How would grinding the lobes affect the diameter of the journals? What am I missing here? All grinding does is re-shapes the journal to either restore original lift and duration or change it. The base circle of the lobe will be decreased (unles material is added first), but with adjustable lifters this isn't a problem.[/quote]
(quoted from post at 07:33:54 01/22/13)
It won't affect the journals , the original post with the quoted archived posting was sarcastic :wink:
