TractorLinks.com
Show Parts for Model:
would you replace the cam shaft
Dave in DE
10-21-2012 20:43:34
If you were completely rebuilding the engine on your 48 8n. would you replace the cam shaft and lifters if they looked to be in good condition?
russb wa
10-22-2012 13:17:10
 Re: would you replace the cam shaft in reply to Dave in DE, 10-21-2012 20:43:34
No. I don't think cams wear much on these slow turning engines w/o rocker arms, if properly maintained, clean oil, correct weight etc.
Dave in DE
10-22-2012 05:19:18
TOH, It would be possable to do that at the machine shop I worked for years ago and it is local. thats where I intend to take the block to be cooked,crank turned, and have valve seats cut.
TheOldHokie
10-22-2012 04:15:07
 Re: would you replace the cam shaft in reply to old, 10-21-2012 20:43:34
I did on my 9N because I was shooting for a "remanufactured" engine. At the time a reground cam was $120 and adjustable lifters were $4 each. I see this site currently wants $21 EACH for new lifters. At that price I'd get a quote on havig the old cam and lifters reground by a local machine shop.
TOH
Dave in DE
10-21-2012 22:58:05
Thanks JMOR, just doing a cost estimate for me and a friend at the momment and wondering if it was a high wear item and liklyhood of needing replaced. my tractor is running fine other than very low oil pressure (7or8 psi hot at 1500). but my freinds has had low oil pressure for years and is now developing a what sounds to be a rod knock. and will need to be pulled down this fall. mine will probably get done next year.
JMOR
10-21-2012 21:20:55
 Re: would you replace the cam shaft in reply to sHan tn, 10-21-2012 20:43:34
Quoting Removed, click Modern View to seeno. But my eyes are not your eyes, either.
