Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Barrs leaks
[Return to Forum]
oldude
10-20-2012 04:06:52
75.207.169.250
Anybody ever use this stuff in a leaky cooling system on n-series ford tractor?
[Reply]   [No Email]
W_B
10-23-2012 06:15:29
155.188.183.23
 Re: Barrs leaks in reply to 36 coupe, 10-20-2012 04:06:52
Used it on my 8N to fix a small leak in the radiator. Followed directions to the letter and still working fine after a year.
[Reply]  [No Email]
heybusdriver
10-21-2012 20:34:23
96.48.198.215
 Re: Barrs leaks in reply to oldude, 10-20-2012 04:06:52
I've used Bars leak on my vehicles for over 45 years , never once had any problem with them after.It seems to seal up but doesn't clog anything.
Stan
2N with 8N motor 8N345567
8N 146710
8N 179555
8N 197904
8N 199000
8N 254079
8N 362039
[Reply]  [No Email]
Ken(Ark)
10-21-2012 17:58:43
71.30.143.205
 Re: Barrs leaks in reply to sHan tn, 10-20-2012 04:06:52
K&D Block Sealer - Follow the directions exactly .
[Reply]  [No Email]
Britcheflee
10-21-2012 21:52:40
67.187.170.181
 Re: Barrs leaks in reply to Ken(Ark), 10-21-2012 17:58:43
My neighbour who rebuilds old crawlers, uses backhoes for a living and who is a do it yourself kind of guy and a damn good mechanic and all round fix it person said this stuff worked for him too - said the same thing...follow the directions exactly.
Lee
[Reply]  [No Email]
oldtanker
10-20-2012 23:26:29
66.228.255.239
Actually it's pretty common in new vehicles that have a cast iron blocks and aluminum heads or cast everything and aluminum intakes for new to have a stop leak chemical added at the factory. After working as a mechanic the only people who I've seen with plugging problems were trying to fix major problems and kept dumping that in some type of stop leak every few days.
Rick
[Reply]  [No Email]
oldude
10-20-2012 15:00:43
75.249.91.47
Can"t fix the leak unfortunately. Its in the water jacket behind the intake port. It"s not a bad leak, just enough that it bothers me. Thanks for everybodies opinion. Big help.
[Reply]  [No Email]
Royse
10-20-2012 13:40:46
69.36.49.151
 Re: Barrs leaks in reply to flembo, 10-20-2012 04:06:52
What part of your cooling system is leaking?
Water pump? Radiator? Block? Hose?
I've use Water Glass to seal quite a few blocks, but it won't help other problems.
[Reply]  [No Email]
grapeview8n
10-20-2012 13:17:48
75.244.55.181
I would stay away from barsleak type products. In the 36 years I've been in the automotive business it has had the reputation of sealing, but risking plugging. The best product I've seen AND used is from GM. It was developed for the aluminum engine blocks. The aluminum block allows the possibility of small passages for the coolant to leak. The GM "seal tabs" were specifically designed to stop these leaks and not clog anything up. To the extent that if you drain the coolant, you have to put the sealant in again because it come out with the coolant. Any GM parts department will have them. They are under $10 for a package that will handle 2 8n cooling systems. Just ask for cooling seal tabs, they'll know what you want.
[Reply]  [No Email]
R Geiger
10-20-2012 09:57:29
50.39.138.117
 Re: Barrs leaks in reply to oldtanker, 10-20-2012 04:06:52
Quoting Removed, click Modern View to see I used it to try and seal leaky head gaskets on a Subaru, and it helped but did not solve the problem. New head gaskets fixed the problem.
[Reply]  [No Email]
pconnie
10-20-2012 08:47:12
67.72.98.46
i always heard over time it would stop up radiator..any truth to this
[Reply]  [No Email]
old
10-20-2012 09:04:46
209.86.226.32
 Re: Barrs leaks in reply to pconnie, 10-20-2012 08:47:12
In all the years I have drove and been around cars and trucks and tractors I have yet o have it clog up a cooling system
[Reply]  [No Email]
old
10-20-2012 08:30:14
209.86.226.32
Yep I have used it in many things over the years that had small head gasket leaks or other such small leaks. I prefer the newer copper barrs leak over the old black stuff
[Reply]  [No Email]
Jim in Ma.
10-20-2012 06:03:04
72.70.106.135
I have used several brands over the years. By far I think Barrs works best. My #2 choice would be black pepper "cheap".
Just remember - That is only a temperory fix.
[Reply]  [No Email]
ZANE
10-20-2012 06:01:17
98.83.98.140
Barr's leak is good in anything.
Best to fix the leak though if possible.
Zane
[Reply]  [No Email]
kylemorley
10-20-2012 08:10:37
96.61.81.253
 Re: Barrs leaks in reply to ZANE, 10-20-2012 06:01:17
On new cars, Barsleak works well enough that a lot of auto manufacturers are using it as a "permanent" repair for cars under warranty with minor head gasket leaks. Whether this is testimony to the manufacturers faith in Barsleak, or parsimony is hard to say. I'd be ripped if I had a brand new car with a leaky head gasket and they just threw in a can or instant fix, but the service people at the local Subaru dealer say it is a lifetime cure as long as you throw in another can every so often.
[Reply]  [No Email]
DEPENDS..John,PA
10-20-2012 16:17:10
209.163.118.90
 Re: Barrs leaks in reply to kylemorley, 10-20-2012 08:10:37
DEPENDS on the OEM Anti-FREEZE. Get a report from BARS LEAK, (tm). In other words, ASK the permission of the manufacture of COMPOUNDS.
German Engineers will always say "NINE". Which means NO in GERMAN. BARS leak looks like something I would not trust to a $40,000. car.
[Reply]  [No Email]
ZANE
10-21-2012 17:14:29
98.83.16.183
 Re: Barrs leaks in reply to DEPENDS..John,PA, 10-20-2012 16:17:10
That's something I don't think I'll ever have to worry about!
Zane
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
