Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 8N Parts Online
wider tires on 8n
10-17-2012 21:36:53
Friend has 60 acres that he has planted in trees. rutted up in spots so hard on front with the narrow tires. Is their a rim off another tractor he can use to put wider tires on front? Thanks for any info
10-18-2012 05:45:01
 Re: wider tires on 8n in reply to oldasdirt44, 10-17-2012 21:36:53
My '49 (second from left) has 16" rims. Makes it harder to steer than the '51 which has 19" tires.
10-18-2012 05:36:08
you can get wide and narrow 16" rims. common to run truck tires on them.. i have a set of truck tires on an 850 for laoder work.
might have to dish a rim if you get pretty wide... or it may rub on the spindle knee
Ultradog MN
10-18-2012 03:24:19
The same bolt pattern - 6 on 6" was used on most Ford tractors all the way in to the 1990s.
Find a set of front rims from like a 5000 which will be much wider and put some used pickup tires on it.
You can also just buy some new rims.
These are some 14" I bought a few years ago to put on the front of my mowing tractor.
I run shorty rims and cheesey little car tires to get the nose down lower. You can buy them new in 14, 15 and 16" in various widths.
10-17-2012 22:16:46
2 different rims were offered on the 8N. A real skinny 19 inch rim and a wired 16 inch rim.
