TractorLinks.com
Order Ford 8N Parts Online
Re: Ford 8n cranking problem
Gary w adams
10-17-2012 20:52:36
Yes it will start and run for about 30 seconds and then stops and will not start again for a while. it is 12 volt and front mount dist.i can not make it run longer than that. it does have spark and has fuel coming out of carb drain.
soundguy
10-18-2012 06:55:29
 Re: Ford 8n cranking problem in reply to Gary w adams, 10-17-2012 20:52:36
starting and stopping, AND it has spark at stop.. and you see fuel running out.
figure fuel issue.
Bruce (VA)
10-18-2012 04:41:08
" it does have spark and has fuel coming out of carb drain"
OK.......
If it has spark & fuel as you say, then it must be running & you can't hear it.
Or maybe it really does not have spark or fuel 30 seconds after it starts and you did not check for one or the other correctly.
That's why I sent you a detailed explanation telling you how to specifically check for spark & fuel as soon as it stops.
Have you done that & didn't tell us? Does the spark jump a 1/4" gap? Does the fuel run out of the carb bowl for at least 30 seconds & only stop when you turn the knob off?
