TractorLinks.com
Show Parts for Model:
installing sleeves
boler76
10-17-2012 18:39:07
pulled out the worn .090 sleeves and purchased new sleeves,pistons etc from this site. Question, if i heat the block will the bore ID get larger or smaller with expansion? Thinking if they get larger and the sleeves are in freezer maybe I can get the new ones in by myself????? Thanks
teddy52food
10-18-2012 14:05:38
 Re: installing sleeves in reply to boler76, 10-17-2012 18:39:07
Do it as in the old hookies vidieo. Then you know they have the right press fit. If you heat the block & cool the sleeves, how are you going to know how they fit as they may be too loose.
GB in MT.
10-18-2012 08:48:07
 Re: installing sleeves in reply to 36 coupe, 10-17-2012 18:39:07
Gaspump said: (quoted from post at 10:10:54 10/18/12) Forget the dry ice, I can't buy it here in my part of FL either. Watch the Old Hokies video and see how easy they drive.
As you can see in the video.....MUCH easier, if you use the RIGHT tool, and less chance of messing up/breaking a sleeve!!!!!!
Watch the video, then contact TOH, for a set like this....MADE BY...'The Old Hokie'.....Pic. of my set of sleeve tools....,.:
BTDT!!!!
Gary :wink:
This post was edited by GB in MT. at 08:49:27 10/18/12.
TOM N MS
10-17-2012 20:25:56
Freezer over night will definitely make the job easier--been many many dropped in the freezer over night then drive in with a hammer hitting a piece of oak board across the top of the sleeve.
Charnerl
10-17-2012 20:15:27
Efforts to install the sleeve without the proper tool or dry ice can colapse the sleeve going in. You can try the freezer first. Clean by honing the block to remove all grease etc.
TheOldHokie
10-17-2012 19:48:38
 Re: installing sleeves in reply to Hobo,NC, 10-17-2012 18:39:07
Just drive them in. Here's a How-To video:
Driving In Thick Wall Sleeves
TOH
Dell (WA)
10-17-2012 18:47:15
boler 76........don't bother yer time with freezing. Gitta pound of DRY-ICE ($1, cheap) from the grocery store (yellow pages) Make a spool of 2-wooden roundy pieces, (they don't haffta be perfectly round, just the bottom on hassta fit thru the sleeve) and some 1/2" all-thread and 4-nuts. Fill the sleeve with chips of DRY-ICE and wait a couple of minutes. With GLOVED hands, slip the DRY-ICE cold sleeve down yer cylinder block. Now un-nut the bottom roundy piece and capture the DRY-ICE chips innna buckett and repeat fer the next sleeve and cylinder. Simple, eh? ........frosty Dell
boler76
10-17-2012 18:49:18
 Re: installing sleeves in reply to Dell (WA), 10-17-2012 18:47:15
Dell, I know dry ice is the answer, but I am 75 miles away from any dry ice supply!
Gaspump
10-18-2012 08:10:54
 Re: installing sleeves in reply to boler76, 10-17-2012 18:49:18
Dell (WA)
10-17-2012 19:18:50
boler76.........what? you want egg in yer beer??? .......sheesh, take a 3-hr break and drive to town, gitta COLD beer and couple of pounds of DRY-ICE in a foam cooler chest. Simple, eh? ........Dell
