TractorLinks.com
Show Parts for Model:
Re: spark plug wires
JCinKY
10-17-2012 09:49:33
I have bought the same set before and was disappointed as you were. Biggest problem I faced was that when I inserted them into my front mount dist cap, you CANNOT get them back out with out pulling the brass contact off.
It pretty bad when you can't even remove the distributor as a whole and work on it on the bench. I'll never buy the cut-to-length again. Get a better set with copper cores and save yourself lots of headache.
In response to your actual question...I highly doubt you could buy off the shelf copper core wires for a 40s-50s 4 cyl at any local auto parts store. Law of supply and demand, little supply = little demand. Gonna have to order em.
soundguy
10-17-2012 10:20:43
 Re: spark plug wires in reply to JCinKY, 10-17-2012 09:49:33
unfortunately, this is still user error.
I use those very same wires on all my ford gassers.
You get MUCH better service fromt he brass pieces if you use a pair of wire cutters and snit them off the sprue, trimming the lil connecting pieces that will catch and cause difficulty in insertion and removal.
Also, trimming the wire back about 1/4" from the end and slipping it thru the smal perfed triangular hole at the base of the clip, and then soldering it, and trimming hte end yeilds a STRONG and good electrical connection. I've never lost a brass clip once soldered .. the go in and come back out fine.
to slip the wire thru the boots, use a bit of silicone.. or even vasolene or that fancy dielectric grease some sets give you.
as with most things in life.. there is no free lunch.
minimal effort yeilds minimal results..
extra effort yeilds extra results.
Not what most people want to hear.. but i've found it to be true.
I havn't kept up with my count lately.. but I wager i've got over 20 tractors, and only a few are diesel.. the rest are gassers. they are ALL using those cut to fit plug wire sets from tsc or similar stores.
-0- issues
soundguy
