Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Help with 2n tranny
[Return to Forum]
BigDanT
10-16-2012 14:54:35
96.60.16.101
I have a 2n with 3-speed with sherman step-up tranny.Had a noise coming from inside tranny and have isolated that to a bad counter shaft.I also had a little bit of tranny oil leaking from cotter key hole in center section. I thought I would try and fix this while i"m in there. Am I right in thinking there is no oil seal for the main drive shaft where it comes through the housing when you"re using a sherman? What would be the likely source of a leak from the sherman tranny? Thanks for any help,
Dan
[Reply]   [No Email]
soundguy
10-16-2012 16:05:57
173.107.180.162
 Re: Help with 2n tranny in reply to BigDanT, 10-16-2012 14:54:35
the sherman uses the exact same input shaft seal that the regualr input shaft would, which it replaces.
[Reply]  [No Email]
BigDanT
10-16-2012 16:44:12
96.60.16.101
 Re: Help with 2n tranny in reply to soundguy, 10-16-2012 16:05:57
Thanks SG
I found that seal and also found another that goes on the shifter rail. I did what I should have done first and went to John Smith's sight,what a wealth in information! Now all I got to do is order the parts and I'm back in business.
Dan
[Reply]  [No Email]
Greg Peri
10-17-2012 10:29:18
129.162.1.37
 Re: Help with 2n tranny in reply to BigDanT, 10-16-2012 16:44:12
Just for your info,
If you plan to replace worn parts (bearings, shift collar, etc) in your Sherman, John Smith and Red Rock Manufacturing (Phil Smith) will probably have what you need.
If'n you need to replace a badly worn Sherman counter-shaft, The Old Hokie can help on that too...
If you replace the Sherman countershaft and find the case is a little oversize, then use some loctite bearing retaining compound at the shaft to case mating surface upon istallation to seal that from a possible leak.
I did not seal mine, so I have a small seepage that makes its way out the cotter key hole below.
Greg
[Reply]  [No Email]
soundguy
10-16-2012 17:36:00
173.107.180.162
yep.. users like john smith and rick B and many others here are loaded with good info!
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
