Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Carryall safety?
[Return to Forum]
kylemorley
10-16-2012 08:18:20
96.61.81.253
I'm using a home made carryall on the 3 point of my 8n to carry
firewood out of the woods where the trailer won't go. Not a
lot of wood per trip, maybe a 5' x 3' x 3" stack, but over some
pretty rough ground.
Seems pretty staightforward to me, but I am wondering if there are
any not-so-obvious dangers to using such a rig I should be aware
of - it does put a bunch of extra weight back of the wheels.
[Reply]   [No Email]
Mark6005
10-16-2012 19:34:01
70.225.176.141
 Re: Carryall safety? in reply to kylemorley, 10-16-2012 08:18:20
Safety is always the primary concern but we do carry 600 plus pound bush hogs and other implements on our n's. A few hundred pounds is not a big deal that requires front weight etc. common sense loading and height travel and you will be fine
[Reply]  [No Email]
NoNewParts
10-16-2012 17:13:45
67.240.145.25
all good advice.
hauling wood thru the woods, add a lot of front end weight.
whatever I think I need , I double it.
really heavy loads that have the front floating,
I drive it out in reverse. slow and just clearing the ground.
Hunting partner once mounted wheels on the very back of his carry-all for
the woods.
[Reply]  [No Email]
Jim.UT
10-16-2012 10:06:14
70.89.244.178
As an addendum to Soundguy's advice to not carry the load higher than needed, be sure it's at least as high as the bottom of the tractor. You don't want the front edge of the carryall catching on an unseen immovable object (stump, large rock) and flipping the tractor over backwards. With the carryall up as high as the bottom of the tractor, anything that will clear the tractor will clear the carryall.
On heavy loads, I like to have my hand on the lift lever, ready to slam it down if the front end starts becoming too light. My foot stays ready to stomp the clutch, too.
[Reply]  [No Email]
Woodchuck
10-16-2012 10:00:55
169.226.69.75
I just picked up a Welco 4' X 4' X18" Utility dump for my 2N.
Definitely need counter weight in the front.
If I fill it to full I can't lift it and it makes the front really light.
http://www.walcoequipment.com/file/dumpbox-utility-3ph_walco_o.pdf
[Reply]  [No Email]
01BIRDDOG
10-16-2012 08:58:33
50.147.88.242
Quoting Removed, click Modern View to seeI just finished putting weights both front and rear today for that very reason. i used inside front wheel split weights on front and they are not seen too bad.
[Reply]  [No Email]
soundguy
10-16-2012 08:22:39
184.246.120.224
the obvious stuff.
strap your load to prevent it shifting and loosing it.
don't carry it higher than needed.
shock loads like tires falling into ruts and whatnot are hard on steering components and safety valves.. etc.. take it slow.
front ballast may be needed if front end is light.
just about anything hung up on a front bumper counts as front ballast.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
