| Ford 9N, 2N & 8N Discussion Forum |
Topic: cam lobe height
[Return to Forum]
| Author |
[Modern View]
| boler76
10-13-2012 13:09:48
184.151.61.218
What is the proper valve lift for a '49 8N Thanks |
| JMOR
10-19-2012 06:10:27
72.181.173.171
Re: cam lobe height in reply to JMOR, 10-13-2012 13:09:48
| Quoting Removed, click Modern View to seeAs correct as I can be given that I did not measure valve clearance, so I make no claim that it is a "cast in concrete" number. Just a better than nothing number. |
| TheOldHokie
10-19-2012 05:15:34
108.8.18.125
Re: cam lobe height in reply to Ultradog MN, 10-13-2012 13:09:48
JMOR said: (quoted from post at 23:39:58 10/18/12)
TheOldHokie said: (quoted from post at 23:30:47 10/18/12)
JMOR said: (quoted from post at 23:19:49 10/18/12)
Ken(Ark) said: (quoted from post at 16:19:30 10/14/12)
| boler76 said: (quoted from post at 16:09:48 10/13/12) What is the proper valve lift for a '49 8N Thanks |
I have been looking for those numbers and have not found any .
I measured 6 USED front dizzy "N" cams and got .296 - .298 for a mean lift . They could all be worn .060 for all I know . I threw a quick digital caliper on them and will use a dial gauge down the lifter/valve bore this winter when I get around to building some N motors . I want to throw a degree wheel on it so I can post those numbers too .
They sell reground cams on this site but I have not talked to anyone who has purchased one .
I would bet these numbers have been measured 1000's of times over the years , but I can't find any posted .
I forgot to write it down , but the bearing journal was the same diameter as a 1937 - 21 stud flathead V8 cam I had in the shop . The V8 cam had a low lift of about .298 also .
I will measure the V8 block for an O.D. cam bearing diameter and post that someday ???
P.S.
These are front mount distributor cams , I think I have read that the side mount cams have a higher lift .
After WWII and the introduction of better fuel , the industry raised compression ratios and valve lifts . The cam was redesigned with the side dizzy so I assume the engineers pepped it up a little ???? |
Well, it was a slow day......so I measured the valve lift on my 8N and my numbers agree with your numbers, as far as my measurement accuracy can be trusted and this is a side mount 8N. I found 0.285 on both I & E. |
OK - I have to ask. How slow was it? Did you have a cam laying on the bench yearning for a mic. Or did you pull one out of a running tractor????
TOH | Neither. I didn't measure the cam itself. As I said, I measured the valve lift..........with a probe thru the spark plug hole against the valve itself. |
OK - just to clarify for folks who may not be as precise and careful as you with their terminolgy :lol:
- Your .285 number is a true measured valve lift measured on the valve itself.
- The cam lift as measured on the cam is actually .010/.012 more to account for tappet clearance.
Which is why you said your .285 number agrees with Ken's .296/.298 camshaft measurements. Correct?
TOH
This post was edited by TheOldHokie at 05:28:40 10/19/12 2 times. |
| JMOR
10-18-2012 20:39:58
72.181.173.171
Re: cam lobe height in reply to Royse, 10-13-2012 13:09:48
| Quoting Removed, click Modern View to seeNeither. I didn't measure the cam itself. As I said, I measured the valve lift..........with a probe thru the spark plug hole against the valve itself. |
| TheOldHokie
10-18-2012 20:30:47
108.8.18.125
Re: cam lobe height in reply to Jubilee85 (VA), 10-13-2012 13:09:48
TOH |
| JMOR
10-18-2012 20:19:49
72.181.173.171
Re: cam lobe height in reply to soundguy, 10-13-2012 13:09:48
| TheOldHokie
10-14-2012 17:08:20
108.8.10.15
Re: cam lobe height in reply to 36 coupe, 10-13-2012 13:09:48
Ken(Ark) said: (quoted from post at 19:49:44 10/14/12) http://www.tildentechnologies.com/Technical/CamHistory.html
http://www.tildentechnologies.com/Technical/FlatheadPerformance.html |
Yep - my source for the flathead data. Also a lot of very good camshaft engineering info there if you are in the mood for some reading.
TOH
This post was edited by TheOldHokie at 17:09:07 10/14/12. |
| Ken(Ark)
10-14-2012 16:49:44
71.30.143.205
Re: cam lobe height in reply to boler76, 10-13-2012 13:09:48
| Ken(Ark)
10-14-2012 16:41:53
71.30.143.205
Just adding info .
Ford Flathead Cam Lobe Designs
TThe Ford Flathead engine used various cam designs. Among these were the Model T cam, Model A/B cams, and the V-8 cams. Camshaft performance was usually described in terms of a number of terminologies in relation to the timing of the valve movements. These include the Top Dead Center (TDC), Bottom Dead Center (BDC), Before Top Dead Center (BTDC), After Top Dead Center (ATDC), Before Bottom Dead Center (BBDC), and After Bottom Dead Center (ABDC).
Model T and Models A/B Cams Specifications
The Model T cam BTDC, ABDC, BBDC, and ATDC were -12, 52, 39 degrees and one degree. Its duration was 220 degrees for both the intake and exhaust. The Lift was 0.250 inches and the Lobe Separation was 115.5 degrees. Model A/B cams BTDC, ABDC, BBDC, and ATDC were 8, 56, 56, and degrees. The duration was longer than that of the Model T cam at 244 degrees. The Lift was also higher at .334 inches during intake and 0.341 inches during exhaust. Lobe Separation was 114.0 degrees.
Flathead V-8 Cams
The Flathead V-8 camshafts came in four versions from 1937 up to 1952. These were the 78-6250 cams from 1937-1948, 8Ba-6250 cams from 1949-1951, 8CM cams from 1949-1950, and the 7HA cams from 1946-1952.
The 78-6250 cams BTDC, ABDC, BBDC, and ATDC were 0, 44, 48, and 6 degrees. It was 5, 44, 48, and 3 degrees for the 8BA-6250 cam, 10, 50, 50, and 10 degrees for the 8CM cam, and 11, 41, 48, and 10 degrees for the 7HA cam. The duration was 224 degrees for the 78-6250, 229 degrees for the 8BA-6250, 240 degrees for the 8CM, and 22 degrees for the 7HA. The 78-6250 and 8BA-6250 had Lifts of 0.307 inches. The 8CM's Lift was .338 inches, while the 7HA measured 0.350 inches. The Lobe Separation for the models ranged from 107.0 degrees for the 7HA up to 111.5 degrees for the 78-6250 cam. |
| TheOldHokie
10-14-2012 14:34:30
108.8.10.15
Re: cam lobe height in reply to MikeT, 10-13-2012 13:09:48
Or one could determine the rocker ratio and simply compute the cam lift needed to get the specified valve lift :idea:
TOH |
| TheOldHokie
10-14-2012 14:29:15
108.8.10.15
Re: cam lobe height in reply to Jim SC, 10-13-2012 13:09:48
The stock valve lift and profile for the flathead cams varied (all numbers taken from original Ford prints):
- 1932-38 Ford V8 used a 6 arc profile with a .307 lift. Camshaft numbers 18-6250 and 78-6250
- 1949-51 Ford V8 used a triple curve profile with a .307 lift. Camshaft number 8BA-6250
- 1949-50 Mercury V9 used a triple curve profile with a .380 lift. Camshaft number 8CM-6250.
- The 1937-48 Ford six cylinder used a triple curve profile with .350 lift. Camshaft number 7HA
The 120 CID 4 cyl camshaft journal diameters are the same as for the V8's. Clevite camshaft bearing set SH-21S fits the V8 and has OD of 1.9275/1.9285. You would need to punch the 120 CID L-head out .131 over to use them in that motor - should be plenty of meat to accomodate that.
TOH |
| Ken(Ark)
10-14-2012 13:19:30
71.30.143.205
P.S.
This post was edited by Ken(Ark) at 13:49:07 10/14/12. |
| JMOR
10-14-2012 07:25:15
72.181.173.171
Re: cam lobe height in reply to TOM N MS, 10-13-2012 13:09:48
TheOldHokie said: (quoted from post at 07:33:05 10/14/12)
JMOR said: (quoted from post at 23:16:17 10/13/12)
JCinKY said: (quoted from post at 23:08:49 10/13/12) http://www.oldfordtractors.com/oftspecs.htm
Not sure if it's 100%, but seemed close enough to rebuild my engine. The "original" copy was soaked in oil in the tool box so it took me awhile to find it again. | Cool! I looked there, but obviously not close enough! Thanks. |
Careful - look at the column dividers in that table. Those numbers are only for the OHV engines - not the L-head.
TOH | Clearly still not looking close enough! :cry:
And if trying to check cam for wear on those OHV engines, one would need to measure at the valve, not the cam lobes, unless he knew the rocker arm ratio, since the chart gives valve lift. That would be obvious to TOH, but maybe not for the world wide population. :wink:
This post was edited by JMOR at 08:03:10 10/14/12. |
| TheOldHokie
10-14-2012 04:33:05
108.8.10.15
Re: cam lobe height in reply to pikewi, 10-13-2012 13:09:48
TOH
This post was edited by TheOldHokie at 04:36:51 10/14/12. |
| JMOR
10-13-2012 20:16:17
72.181.173.171
Re: cam lobe height in reply to Stephenscity, 10-13-2012 13:09:48
| Quoting Removed, click Modern View to seeCool! I looked there, but obviously not close enough! Thanks. |
| JCinKY
10-13-2012 20:08:49
166.147.120.157
| JMOR
10-13-2012 19:06:07
72.181.173.171
Re: cam lobe height in reply to Bruce (VA), 10-13-2012 13:09:48
| Quoting Removed, click Modern View to seeSource? |
| JCinKY
10-13-2012 17:42:29
166.147.120.156
Intake=0.3553
Exhaust=0.3370 |
| boler76
10-14-2012 03:21:22
184.151.61.255
Re: cam lobe height in reply to JCinKY, 10-13-2012 17:42:29
| Thanks that is the info I was looking for |
| TheOldHokie
10-13-2012 15:30:17
108.8.10.15
JMOR said: (quoted from post at 17:13:47 10/13/12)
| boler76 said: (quoted from post at 16:09:48 10/13/12) What is the proper valve lift for a '49 8N Thanks | You are not likely to find that number.. From those who really should know, it is said that the cam wears very little due to small spring pressure and the fact that lobes are flame hardened. I would measure all & compare to one another & if all are about same, call it good. |
Here is an interesting little graphic. FWIW a high performance Crane cam for a V8 Ford flatty is pushing .400 lift.
This source is a treasure trove of information and says a stock flatty was .307: Camshaft Design History
TOH
This post was edited by TheOldHokie at 15:50:03 10/13/12 2 times. |
| JMOR
10-13-2012 14:13:47
72.181.173.171
Re: cam lobe height in reply to Herman Nielsen, 10-13-2012 13:09:48
| Quoting Removed, click Modern View to seeYou are not likely to find that number.. From those who really should know, it is said that the cam wears very little due to small spring pressure and the fact that lobes are flame hardened. I would measure all & compare to one another & if all are about same, call it good. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
