| Ford 9N, 2N & 8N Discussion Forum |
Topic: pto shaft difficult snap rings
[Return to Forum]
| Author |
[Modern View]
| RJ IN WYO
10-12-2012 09:17:30
184.166.200.153
re plaseing oil seal on my 51 8n. the last one i did i had trouble removing the large snap rings. pry with screwdriver and a lot of cussing is there a easie way or a large pair of snap ring pliers that arent expensive. it maybe my mechanical abilty tthat may be the problem thanks rj in wyo |
| 36 coupe
10-14-2012 14:04:38
66.186.169.176
Re: pto shaft difficult snap rings in reply to RJ IN WYO, 10-12-2012 09:17:30
| If you complain about tools being expensive you will do without them for years and use make shift methods.I bought my snap ring pliers back when I was making 40.00 a week.Still in my tool box and helped on trans mission work for 55 years.Try opening gas lines with out the right tools.Doing with out good tools is false economy. |
| Royse
10-12-2012 18:40:23
69.36.49.151
| Quoting Removed, click Modern View to see
It's all about pocket protectors......I mean....I understand what you're saying! :)
I've got one of these to do myself. Thank you all for the information! |
| TheOldHokie
10-12-2012 16:53:11
108.8.10.15
Re: pto shaft difficult snap rings in reply to Colin King, 10-12-2012 09:17:30
John Smith8N said: (quoted from post at 19:29:53 10/12/12)
They are the same as the ones in the pto shifter housing. Being internal, any type of plier just sets them tighter into their groove. Like Chris said, two small pocket screwdrivers and about 5 seconds time will spiral them right out. |
OK - got it. I was under the (miss)impression they were external. I've had my hands on the shifter ones and I am familiar with that process. You must have had more practice than me because I struggled with them :oops:
TOH
This post was edited by TheOldHokie at 16:56:16 10/12/12. |
| soundguy
10-12-2012 17:42:33
107.41.13.249
Re: pto shaft difficult snap rings in reply to TheOldHokie, 10-12-2012 16:53:11
| | I think every dern ford I've bought has the dreaded leaky pto seal or bad bearing.. seems nobody wants to fix em... thus, that lil drill John smith talked about does tend to get 'practiced' alot. he's right. once you pop one edge and anchor it a bit, the other screwdriver just chases it out. kinda like using 2 tire spoons and dismounting a tire.. if you can relate to that. and he does mean smal.. no large screwdrivers. the lil kind with a clip that you can put in a shirt pocket and then realize you just messed up your shirt.. :) |
| John Smith8N
10-12-2012 16:29:53
75.23.112.234
| soundguy
10-12-2012 14:17:42
173.107.183.70
| 2 small flat blade screwdrivers will pop and chase the ring out. No special tools needed. ( though you can certaintly use them if you have them! ) |
| TheOldHokie
10-12-2012 13:21:46
108.8.10.15
Re: pto shaft difficult snap rings in reply to Royse, 10-12-2012 09:17:30
John Smith8N said: (quoted from post at 13:41:26 10/12/12)
Snap ring pliers, good or not, won't work on a pto snap ring.
Those are "different" and similar to the internal ones used to retain the bearings in the PTO shifter housing. The PTO housing ones are a real PITA. These look to be a variation on modern constant section retaining rings that are designed for thrust loads. I have a pair of "flat nose" external snap ring pliers that I suspect will "get-r-done". I bought the pliers for similar rings used to locate the shaft bearings on the belt drives in my lathes. Got to be better than a couple screwdrivers.
TOH
This post was edited by TheOldHokie at 13:50:15 10/12/12. |
| John Smith8N
10-12-2012 10:41:26
75.23.112.234
Re: pto shaft difficult snap rings in reply to tumleweed, 10-12-2012 09:17:30
| TheOldHokie
10-12-2012 09:25:15
108.8.10.15
Re: pto shaft difficult snap rings in reply to Jeff Mead, 10-12-2012 09:17:30
Invest in a good pair of fixed tip external snap ring pliers. Not one of those one size fits all internal/external convertible pieces of junk. I like the heavy duty Knipex pliers from McMaster - they make life so much easier:
Knipex Retaining Ring Pliers
TOH |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
