| Ford 9N, 2N & 8N Discussion Forum |
Topic: 8N Carb problem
[Return to Forum]
| Author |
[Modern View]
| Mike Parsley
10-11-2012 20:06:19
70.192.198.7
I have recently rebuilt the carburetor on my 52 8N and now it will only run when I use the fuel bowl to gauge the fuel flow. If I open it up the full 2 turns it will flood and fuel drips from the bottom of the bowl. I am thinking that the float is stuck. Any other thoughts of suggestions would be appreciated. |
[Reply] [No Email] | |
| Mike Parsley
10-13-2012 06:35:46
70.192.192.126
Re: 8N Carb problem in reply to Mike Parsley, 10-11-2012 20:06:19
| Thanks a lot for the responses. I plan on pulling the carburetor apart this morning and hopefully correcting the problem. |
| GB in MT.
10-12-2012 06:30:31
216.47.49.75
Re: 8N Carb problem in reply to DrLarryE, 10-11-2012 20:06:19
Mike;
ALL good replies here for you,......
As JMOR told you......."bad needle & seat, wrong float setting, or leaking needle seat gasket (not tight enough)."
I would also check the floats for dents,(Scrubbing on the side of the bowl),....and also check the floats for leakage,...(floats, filling with fuel,.... makes the floats inop., and setting on the bowl bottom!!)
Check the center of this pic., for float setting!!!:
Also here are my settings for the M/S TSX carbs, and how to set the carb up properly, to your engine:....
If you have more ??'s, post back here with them, or you can email me for more info., to help you get the carb running right!!!
Email is ALWAYS open at the bottom, of my posts, and or replies, on the 'Modern' side of this forum. Just push the email button there, and fill in the blanks!!
Gary :wink: |
| TOM N MS
10-12-2012 03:43:25
98.95.140.91
| Check to be sure the float is not scrubbing the walls of the bowl--happens sometimes. |
| old
10-11-2012 20:48:56
209.86.226.40
| Rubber tipped float needle????? If yes you need to put a set in ti or yes it will do that. Just did a 8N carb yesterday and did not have that problem but I #1 set the float at the correct level #2 I put a set in the float needle before I button it up. To set the needle you drop it in the the seat then tap on the needle a few times. That put a set as in if your eyes are good you see a ring on the rubber tip. |
| JMOR
10-11-2012 20:20:31
72.181.173.171
Re: 8N Carb problem in reply to FLAcharlie, 10-11-2012 20:06:19
| or bad needle & seat, wrong float setting, or leaking needle seat gasket (not tight enough). |
| Billie R. Smith
10-11-2012 20:16:47
69.245.108.151
| Sounds like the float to me. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
