| Ford 9N, 2N & 8N Discussion Forum |
Topic: Rust on interior of rim
[Return to Forum]
| Author |
[Modern View]
| murray2
10-08-2012 16:25:01
142.134.47.75
Removed the tires off the rims today. One tire was loaded with calcium, previously had leaked. The interior of the rims is fairly rusty. Started to clean up with wire brush. What type of paint or good sealer could be applied, so as not to damage a new tube. Thanks, Murray |
[Reply] [No Email] | |
| soundguy
10-09-2012 05:53:16
184.245.112.212
Re: Rust on interior of rim in reply to murray2, 10-08-2012 16:25:01
| | clean it up good. electrolysis is good if you have a place to put the rim ... otherwise chemicals like naval jelly or driveway iron rmeover / clr will eat it.. ( phosphoric acid ) once rust is gone.. weld or braze fix any holes or thin spots. then prime and paint. some like rusty metal primers and rust control paints by rustoleum and others. can also go for epoxy paints.. some rust control sealers like por15 are good.. and go what others say and use a sealing or ruberizing undercoating.. cold zinc finishes.. etc.. lots of preps. pitting, once cleaned up and primed and painted shouldn't other a tube. if you weld a patch on and can't grind it good.. do as another poster said. after paint is cured.. roll some duct tape in and around it... it DOES work.. :) i found a boot/cut up tube taped to the inside of a rim before.. |
| russb wa
10-08-2012 22:19:33
67.185.6.72
| Zinc Chromate primer has some sort of chemistry going on. Thats what I recommend. Then paint on top. |
| Billie R. Smith
10-08-2012 19:46:45
69.245.108.151
| One of mine is wrapped with duct tape. |
| old
10-08-2012 17:40:39
209.86.226.32
| The best thing I have found is the spray on bed liner stuff. It is made to hold up to a lot of stuff and in theory should hold up to most any thing that would be spilled in the bed of a truck so it holds up well on the inside of a rim. I have used it many many times. Plus if you want to go the extra step get it rhino lined and it has a life time warranty |
| Royse
10-08-2012 16:58:02
69.36.49.151
Re: Rust on interior of rim in reply to TheOldHokie, 10-08-2012 16:25:01
| I used Rustoleum primer and paint on mine.
There is also a rubber rim band you can put around the rim under the tube. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
