found a product that actually does what it says...
i have a variety of pneumatic tires on the farm.. wheel barrowm CUV, tractgors.. some gate wheels.. etc.. lawnmower.. etc.
some are tubed.. some not.
on my lawnmower for instance, not tubed.. but the rubber itself is porous.. can pump the tire up and weight it in the horse tough and a few hours later it has white 'foam' micro bubbles on it.
in days it goes flat.
for things like that I used slime or fix a flat. got decent results.. the slime seems to wear out and stop working in a couple years...
have a big gate tire that did the same and tried this stuff from tractor supply.. was on sale from 15 to 10 for 2 bottles.. comes with a tire valve remover anda transfer hose.
pumped some into my gate tire with the squeezy bottle... rolled it around for 5 minutes and reinstalled. i wiped the residue off the bottle and left it on the rubber truck mudflap that doubles as the topper for my work bench. the white stuff sets up like rubber.. in fact.. reminds me of latex... maybee it is?? in any case.. had it in that tire for a couple weeks now. this tire would go flat weekly.. abd be low mid week. just checked it and it is holding the 24 psi i put in it 2 weeks ago. stuff claims to make a tube like liner in the tire.. well.. i guess it does.
looks like it would be great for a tube or tire with a slow pinhole leak or porous rubber or perhaps a dirty bead...
says no hiway / high speed use.. my guess is it clumps and doesn't spread out 100% even by cure time and thus could make an imballance for a car tire.
if this suff doesn't go wattery and break down like slime.. well.. I'm sold! i hate opening a tire with old slime in it.. nast gunk.
mind you.. i bet this makes a ream mess on a non tubed rim.. probably a bear to clean..
