Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 450 ft pounds!!!
[Return to Forum]
Britcheflee
10-02-2012 06:56:42
67.187.170.181
I see that the rear axle main nut needs to be tightened up to 450 ft pounds - guess I am going to have to put a large pipe wrench on it with an extra piece of pipe to lever that down!
I dont even think my torque wrench setting goes up that high.
Lee
[Reply]   [No Email]
TheOldHokie
10-04-2012 04:54:48
108.8.21.48
 Re: 450 ft pounds!!! in reply to GB in MT., 10-02-2012 06:56:42
Hobo,NC said: (quoted from post at 21:49:11 10/03/12)
If you are up to a challenge...
Loosen the lug nuts on your car/truck lay 100lbs on the end of a ft bar to tighten the nuts then go drive it... Make sure you insurance is paid up....
Let us know how it works out for ya...
I have complete confidence that it is tight enough. That is exactly what a high dollar torque wrench is doing when you set it to click at 100 lb-ft. Here is a good read on the matter:
Fastener Training Institute - Torque and Tension (4MB PDF)
TOH
This post was edited by TheOldHokie at 05:48:54 10/04/12 2 times.
[Reply]  [No Email]
Hobo,NC
10-03-2012 18:49:11
98.17.81.103
 Re: 450 ft pounds!!! in reply to Ultradog MN, 10-02-2012 06:56:42
[Reply]  [No Email]
TheOldHokie
10-03-2012 07:27:23
108.8.11.239
 Re: 450 ft pounds!!! in reply to ShadetreeRet, 10-02-2012 06:56:42
No my friend - this is basic physics pure and simple. Torque is torque - friction has nothing to do with it. A 150# man on the end of a 3' bar produces exactly 450 lb-ft of torque. Jumping on the bar simply produces more than 450 lb-ft of torque becasue you are using gravity to "increase" your static weight (force) with an acceleration force.
Friction enters the picture when we try to use torque as an indirect measure of the clamping force (tension) created in a threaded fastener as we tighten it. That friction varies with the materilas the fasteners are made from and the condition of the threads (oiled, greased. plated. etc). All of those factors are already included by the engineers in the 450 lb-ft specification for tightening that nut. Applying a greater torque simply produces a tension greater than the engineers wanted.
TOH
[Reply]  [No Email]
Hobo,NC
10-03-2012 05:12:16
98.17.81.103
 Re: 450 ft pounds!!! in reply to Dave/MO, 10-02-2012 06:56:42
In theory yes in reality no...
http://ytforums.ytmag.com/viewtopic.php?t=938730&highlight=bounce
[Reply]  [No Email]
NoNewParts
10-02-2012 16:49:27
67.240.145.25
 Re: 450 ft pounds!!! in reply to Britcheflee, 10-02-2012 06:56:42
makes ya wonder what the actual torque reading is,
that you are applying, when you are trying to get a stubborn one
loose that has the threads bottomed out :D
[Reply]  [No Email]
Den N Ms
10-02-2012 14:52:47
74.177.2.94
How about a 2" 3/4 drive socket?
[Reply]  [No Email]
jerry/MT
10-02-2012 12:47:51
206.183.116.145
Use a cheater bar and stand on it! 450 ft-lbs means "real tight".
[Reply]  [No Email]
Ultradog MN
10-02-2012 07:07:39
174.20.253.54
It's not that much really.
If you weigh 150 lbs, hanging on the very end of a 3' long wrench would get you there.
[Reply]  [No Email]
CJ in Michigan
10-02-2012 07:40:33
24.247.148.35
 Re: 450 ft pounds!!! in reply to Ultradog MN, 10-02-2012 07:07:39
2' does it for me-
[Reply]  [No Email]
Ultradog MN
10-02-2012 11:56:18
174.20.253.54
 Re: 450 ft pounds!!! in reply to CJ in Michigan, 10-02-2012 07:40:33
LOL
We must weigh about the same amount.
[Reply]  [No Email]
Britcheflee
10-02-2012 07:55:44
67.187.170.181
I guess that compresses down the inner rubber seal on the spline of the axle as well to make the hub seat properly?
[Reply]  [No Email]
ASEguy
10-02-2012 15:27:46
68.186.162.134
 Re: 450 ft pounds!!! in reply to Britcheflee, 10-02-2012 07:55:44
I put RTV on the splines to prevent fluid leaking through.
[Reply]  [No Email]
Britcheflee
10-02-2012 23:06:29
67.187.170.181
 Re: 450 ft pounds!!! in reply to ASEguy, 10-02-2012 15:27:46
yes, did that, got it tight - but assuming I can really crank down on it when the wheel is back on?
[Reply]  [No Email]
ASEguy
10-03-2012 10:04:18
204.184.80.25
 Re: 450 ft pounds!!! in reply to Britcheflee, 10-02-2012 23:06:29
If you wait the RTV would have set up and tightening more may "break" the seal. I put a rod between the lugs for the wheels and braced it against the ground when I tightened mine. Gerard
[Reply]  [No Email]
Dell (WA)
10-02-2012 08:59:33
63.226.208.142
Lee........NO, the BIG NUT only touches the shoulder of the splined axle thru 1-washer. Look at yer FO-4. And YES, 450ft/lbs BEFORE you put the snap-ring on the outside of the BIG NUT. Iff'n yer really sphincterly challenged, you can RENT a 3/4"-drive torque wrench with 1-15/16 socket. And NO, you don't want to buy a 600ft/lb 3/4"-drive torque wrench. ........the tite Dell
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
