11/16 wrench 9n tractor
Anonymous-0
Where do i bend the 11/16 wrench to take out the relief valve?
I dont have the the tractor opened up yet so i dont know how far i need to bend the wrench thought i would ask before i open it up?
Any replies will be appreciated
Thank You
Bob Lucas
he's obviously talking about the hydro pump relief valve, changing it thru the inspection ort, with the pto shaft installed and in the way.
Sorry for not saying the hydro relief valve. Yes i have a socket i am going to open up the cover side that throws in the hydraulics in gear. Can i do it with a socket?
Thanks
Bob LucaS
No, but you can do it with a cheap set of J. C. Whitney S and C box end wrenches.
If you have the OEM style relief valve with the cotter pin through the end, you will spend more time removing the cotter pin than changing the valve.
Dean
I just done one a month or so ago , all I did was remove PTO shaft , reach in from the left side with a normal boxend wrench, break the seal and after it is broken unscrew it with my fingers. For assembling did the opposite , screwed it in with mt fingers and then snugged it up with the same wrench. Mine didn't have any cotter key in it , maybe I got lucky.
Stan
2N with 8N motor 8N345567
8N 146710
8N 179555
8N 197904
8N 199000
8N 254079
8N 362039
