| Ford 9N, 2N & 8N Discussion Forum |
Topic: 8N front leak
[Return to Forum]
| Author |
[Modern View]
| Bruce Gallaway
09-27-2012 19:42:35
98.244.17.39
We have a front engine oil leak,in the front main or pan region. How do we change the front main seal and or pan gasket? We are new with the 8N but reasonable mechanics. Gray hair and educated advise would be appreciated. Bruce |
[Reply] [No Email] | |
| Richard G.
09-28-2012 05:51:16
98.84.70.20
Re: 8N front leak in reply to Bruce Gallaway, 09-27-2012 19:42:35
| Been thinking my front seal was bad on my 8N for a while. Got to looking and a pan bolt is broken off near the front on the left side and the leak is coming from that. It is in the curve of the pan near the front. Plan to fix it this winter. Richard |
| TOM N MS
09-28-2012 02:35:43
98.95.142.224
| If your leak is at the front crank rope seal, you might want to consider the one piece neoprene replacement seal..I did....Others will come along with opinions on this option..Worked good for me-3-4 yrs ago and still no leak.. |
| Bill Rowles
09-27-2012 23:49:16
76.2.232.2
| If you pull off the oil pan, check to be sure the oil "slinger" (part # 6310) was installed on the front of crankshaft between the gear and the belt pulley. If that is missing due to mis-assembly could be the problem. |
| JCinKY
09-27-2012 20:00:05
166.147.120.147
| Quoting Removed, click Modern View to see
Bruce...you will have to drop the pan, which will need you to remove the front end. 6 bolts on the bolster, radius arms, and drag links. You can just roll it out with the rad if you drain and disconnect the hoses. Oh yeah, self explanatory to remove the hood (get a buddy to help) drain the oil, and block her up good at the tranny.
Drop the pan, don't forget the 4 bolts that connect it to the bell housing. There are two at the very front and may be hard to see, easy to miss. Front main is two part rope seal. Lots of people get by with just replacing the bottom half, easy. Full replacement requires you to drop the crank or try and fish the top half out. Then reverse for install.
Pan gasket is easy, just forget everything I said about the front main. There are two others that could leak, timing cover and governor, but we won't get into that for now, until you let us know exactly where its coming from
No gray hair required, just lots of wrench time. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
