Topic: Re: Which end up? Power steering ??
[Return to Forum]
| Author |
[Modern View]
| Royse
09-25-2012 20:18:25
69.36.49.151
Here's the mock up, not tested yet.
Edit: original post - here
This post was edited by Royse at 20:36:07 09/25/12. |
| Royse
09-26-2012 19:09:36
69.36.49.151
Re: Which end up? Power steering ?? in reply to WaltMo, 09-25-2012 20:18:25
| Quoting Removed, click Modern View to see
Thank you both for your interest an help!
It is a control valve that drives one DA cylinder.
One pressure line, one return line, two directional lines to the cylinder.
I guess my question stemmed from wondering if gravity would empty the valve
if the return was on the bottom versus on the top, and what would happen if it did.
Hopefully I'll get it finished up this weekend so I can let you know how it works. |
| JMOR
09-26-2012 18:08:04
72.181.173.171
Re: Which end up? Power steering ?? in reply to Notjustair, 09-25-2012 20:18:25
| Quoting Removed, click Modern View to seeDon't think it is a 'torque amplifier' like the Charlynn on Farmalls, but rather just a control for the double acting cylinder attached to steering links/rods. On those Farmalls, there is no other cylinder, just the single device inserted inline with the steering wheel shaft. |
| JMOR
09-26-2012 18:07:33
72.181.173.171
Re: Which end up? Power steering ?? in reply to Hobo,NC, 09-25-2012 20:18:25
| TheOldHokie
09-26-2012 17:59:05
108.8.6.218
Re: Which end up? Power steering ?? in reply to 1951 8N, 09-25-2012 20:18:25
Possibly because it might be a torque amplifier and doesn't drive a cylinder. After counting hoses I discounted that idea :?
TOH |
| Royse
09-26-2012 09:24:43
68.77.236.5
Re: Which end up? Power steering ?? in reply to ken and dogs, 09-25-2012 20:18:25
Hmmm, clear as mud. Sorry about the confusion. :oops:
Yes that is correct.
Specifically I was wondering about the return line.
Mechanically I wouldn't think it would matter, but would it make any
difference if the return line is on top or bottom? |
| JMOR
09-26-2012 09:06:50
72.181.173.171
Re: Which end up? Power steering ?? in reply to CharnerL, 09-25-2012 20:18:25
| Quoting Removed, click Modern View to seeCommunications is sure difficult sometimes......all along I thought you were trying to figure out the hose position/connections, but now I think you were concerned about which end (mechanically) does the steering wheel connect to? Is that right? OK, so does it make a difference which end steering wheel connects to & if so, why? Realizing hoses could be swapped. |
| Royse
09-26-2012 08:36:33
68.77.236.5
Re: Which end up? Power steering ?? in reply to soundguy, 09-25-2012 20:18:25
I think you're right Joe, although I haven't been able to find a name on it.
This one is also going on an NAA with a single cylinder just as you say. |
| Royse
09-26-2012 08:34:20
68.77.236.5
Re: Which end up? Power steering ?? in reply to Royse, 09-25-2012 20:18:25
Mapping them wasn't really an issue because it was mostly still assembled when I got it.
The top hose was connected to the high pressure side of the pump and
has a unique fitting that wouldn't connect anywhere else.
The lower hose has a low pressure barb fitting to go back to the resevoir.
The two side hoses were already connected to the cylinder that helps you
move the draglink. The fittings will only fit there, although they could be reversed.
I did end up hooking up my air hose to it so I could tell which of those two hoses were
pressurized when turning left or right.
I have left the cylinder loose from the draglink so I can find the "neutral" position
on the cylinder movement and then tighten it in place.
It is a first time project for me, so recommendations are welcome. |
| Royse
09-26-2012 08:15:57
68.77.236.5
Excellent idea! I might have to add a nipple to the top one to space it out a little over the lower one, but it would look much cleaner and take some strain off the hoses.
Thanks! |
| old-9
09-26-2012 07:51:29
67.236.117.163
| That looks like a "Char-Lynn" power steering unit. They were used on John Deer, IH, and others. I have a friend that has one on an NAA. Uses only one cylinder, but works very well. joe |
| JMOR
09-26-2012 06:58:48
72.181.173.171
Re: Which end up? Power steering ?? in reply to Bob Harvey, 09-25-2012 20:18:25
| Quoting Removed, click Modern View to seeJust curious, but how did you ultimately 'map' the ports? |
| TheOldHokie
09-26-2012 06:53:47
108.8.6.218
Re: Which end up? Power steering ?? in reply to Dave8N in Pa, 09-25-2012 20:18:25
Might I suggest some 90* port adapters to turn the hose runs straight down and to the sides.
TOH |
| Kurt-NEPA
09-26-2012 04:40:12
70.44.245.96
| Keep us posted Royse, I've never seen this aftermarket system before. I'd like to see how this works out.
Looks to me like this a single cylinder system. Leave the cylinder disconnected when you fire it up. That way you can see if you have going the right way.
Also, to bleed the air out, jack up the front end and move the steering wheel full and right and then full left a few times. That will get all the air out. At least that's the way the stock system works.
Good Luck! |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
