Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: How much vinegar in radiator?
[Return to Forum]
Bob Purinton
09-23-2012 04:57:19
74.46.244.71
I'm putting a new radiator on my 8N because the old one has loose fins and two holes in the core. I managed to do that when straightening the fins.
Anyhow, The engine has some sludge in it and I remember someone posting about adding vinegar to the water to clean this up. How much vinegar? I got a gallon on sale at Walmart. Use all of it or what? thanks.
[Reply]   [No Email]
36 coupe
09-26-2012 03:30:35
66.186.169.176
 Re: How much vinegar in radiator? in reply to Bob Purinton, 09-23-2012 04:57:19
Vinegar is a mild acid.You will need 3 gallons.Washing soda will do a better job and cost less.
[Reply]  [No Email]
Bob Purinton
09-23-2012 12:21:12
74.46.244.71
Thanks for the answers; but, I don't have the new one on yet. As a matter of fact; I just now got back from picking it up. I'm about to go switch things out now. I'll flush the system as someone described and put the new one on. I'll post pictures later as the new radiator is a lot different than the original one.
[Reply]  [No Email]
Bruce (VA)
09-23-2012 05:58:07
24.125.80.178
Remove the t-stat from the top hose. Then, remove the bottom hose from the radiator & stick your garden hose in the radiator. Turn the water on (reverse flush) & the water will flow into the radiator, then the block & out of the disconnected lower hose. Let it run until the water is clear. Then, check the radiator flow. Stick the hose in the top of the radiator; the water should flow out of the bottom w/o backing up in the filler neck. It should flow at 19.5 gallons a minute. As a final flush, put a gallon of white vinegar & about 2 gallons of water in the radiator, run it to operating temp & then drain it again. Don’t forget to put the t-stat back in correctly!
Use 50/50 anti-freeze & distilled water as your coolant. The anti-freeze contains rust inhibitors, pump lubricant & raises the boiling point of the coolant.
[Reply]  [No Email]
leej
09-23-2012 05:50:31
216.73.235.175
When the old radiator was off ,at that time you should have flushed the engine, which would have been real easy. Now with the new radiator on ,when you flush it, the crud will start to plug the new one. ggp
[Reply]  [No Email]
Bob Purinton
09-23-2012 05:00:55
74.46.244.71
I forgot to add; How long do I leave the vinegar in for? I'm running straight water for now. Antifreeze will go in when sludge is cleaned out of passages.
[Reply]  [No Email]
old
09-23-2012 09:22:04
209.86.226.19
 Re: How much vinegar in radiator? in reply to Bob Purinton, 09-23-2012 05:00:55
You fill the cooling system up with pure vinegar then run it till good and warm. Let it sit till cooled down then drain the system. Then rig up a way to hook a garden hose to the block drain and back flush the system. Rigging up a hose if easy to do with a couple pipe fittings and a piece of old hose
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
