| Ford 9N, 2N & 8N Discussion Forum |
Topic: 8N oil pressure
[Return to Forum]
| Author |
[Modern View]
| labman98
09-22-2012 18:25:19
208.81.196.42
Looking thru the many previous threads on this subject I have not found an "fix" so I am going to ask this question again and hope to get some sort of answer. Just finished putting an 8n back together and went to start it and at start get 20-25psi and once it warms up goes down to 5ish. I added new rod bearings, main bearings, sleeves, pistons, rings, but nothing with the oil pump itself. Mains have .002 clearnace, rods have .004. Rods are a little high but still within max allowance (.005) I dropped the pan this morning and took the oil pump out. The gears are a little pitted but not to bad. The shaft and bushing are tight and measure to spec. One thing I cannot find a spec on is the gear to removable plate clearance. There is some wear on this plate and I will clean that up before it goes back together. Is there a spec for this? Or gaskets to adjust this clearnace? I have seen this on cars and it helps greatly to tighten this up with thinner gaskets. Any ideas on where else to look? Thanks in advance. |
| TheOldHokie
09-23-2012 05:31:27
108.8.11.177
Re: 8N oil pressure in reply to Sphere, 09-22-2012 18:25:19
| Quoting Removed, click Modern View to see
Ideally end clearance on the oil pump gears should be .002-.003. Gear lash should be max of .003-.004. There should be zero pitting or visible wear on the gears. If you have visible scoring or wear on the pump cover or gears it needs to be corrected.
At .004 your rod bearing clearances are getting pretty sloppy and will undoubtedly have an adverse effect on oil pressure. Did you check camshaft journal clearances or just hope fior the best?
Remember - the wear limit is the absolute maximum acceptable clearance and well beyond what you want new. A rebuild that starts out at or near the wear limit isn't going to perform "like new" or last very long.
TOH |
| CharnerL
09-22-2012 20:44:51
66.175.156.48
Re: 8N oil pressure in reply to labman98, 09-22-2012 18:25:19
| If you still have the pan off, check the pick-up tube. The least hole, pin hole will cause severe drop in pressure. I air pressure test each one and find that about every other one had an air leak at the head of the tube. |
| Jerry/MT
09-22-2012 19:59:33
206.183.116.145
| Check the relief valve. Make sure it isn"t stuck open or has a weak spring. |
| JCinKY
09-22-2012 18:36:05
166.147.120.144
| Lab...my 50 8n is the same way. 25 cold, 8 hot. I rebuilt mine with bearing, rings valve job AND rebuilt the oil pump. My "cap" was scored as well. Sand out any grooves with emory on a piece of glass to stay flat.
Oil pump should have a gasket. I set end play by installing drive gear until too tight to turn by hand then back off until free. Housing could be worn, pressure relief spring too loose (easy fix, stretch or I bought new). You can also lose OP in the cam. Check cam bore in block and cam journals to nominal.
My crank plastigaged to 003 on rods and mains. Looking for a cam, don't want to bore and install bushings.
Oh yeah...galley plugs in? 5lbs not terrible will run a long time on low OP. Just don't idle all day.
Post back -Jeff |
| old
09-22-2012 18:29:49
209.86.226.19
| Year ago I had an 8N that had low oil pressure and found the oil pump gear plate that has the pick up was ruff. I used a flat surface to lay some sand paper on and sanded out the starches and the oil pressure came right up. Also the pressure relief valve could be set to lot or the spring could be weak which would also cause that problem |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
