Topic: Carb mystery
[Return to Forum]
| Author |
[Modern View]
| W_B
09-21-2012 08:38:16
155.188.247.17
I talked with Gary a few days ago about my TSX 241 rebuild (Thanks, Gary, it works great! Put it on the 9N since the 8 isn't running now). My main question was about the throttle shaft not having the normal brass retainer ring and rubber seal in it, instead it has a brass bushing pressed into the body. The new shaft fit in very snug with no side-to-side movement, and since I couldn't get the bushing out I left it. The choke shaft had the ring and rubber seal instead of the ring and fuzzy packing. I replaced it with the ring and fuzzy packing as Henry made it. As I said all works fine.
I took the carb from the 9N (a TSX 33) and upon taking it apart I discovered it is exactly the same way as the other, brass bushing in the throttle shaft and ring and two rubber seals on the choke shaft. There was the fuzzy packing on the throttle shaft between the bushing and the throttle lever. Difference between the two carbs is I know where this one came from... I bought this carb rebuilt from the local Ford tractor dealer 20 yrs. ago when I first got the tractor. The 241 was on the 8N when I bought it at a sale a couple of years ago and I have no knowledge of what had been done to it.
My theory is that whomever was doing rebuilds for Ford was doing them this way. I suspect the 241 was an older rebuild too and probably from a Ford dealer (no internet ordering in those days, kiddies!).
Anyone else run into this? Really had me confused since none of the literature had mentioned the brass bushing on the throttle shaft as something I might see and Gary indicated he hadn't seen that either (although Gary can certainly speak for himself). |
| W_B
09-21-2012 11:22:30
155.188.183.18
Re: Carb mystery in reply to cletrac68, 09-21-2012 08:38:16
| They had a rubber bushing/seal that was held in by a small brass retainer. I suppose if those were worn enough the shaft might wear the throttle body, although I'm not sure what would wear more, the brass shaft itself or the carb body (not up on my metallurgy)?
Maybe this was supposed to be an upgrade... are the carbs on the NAA and 100 series like this (have a solid bushing)? |
| rustyfarmall
09-21-2012 11:37:57
67.55.162.174
Re: Carb mystery in reply to W_B, 09-21-2012 11:22:30
| Quoting Removed, click Modern View to see
The Farmall H and M carbs all have brass bushings from the factory. The throttle shaft is usually the first to wear out, but eventually that bushing needs replaced also. I've rebuilt several that had way too much play even with a brand new shaft, so then I replace that bushing.
For what it's worth, the new bushings I use have Ford part numbers on the package. |
| rustyfarmall
09-21-2012 09:29:52
67.55.162.174
Re: Carb mystery in reply to W_B, 09-21-2012 08:38:16
| Just a wild guess here, but did those carburetors have any kind of replaceable bushing for the throttle shaft when they were new? If not, maybe the area where the throttle shaft fits became worn enough that even a NEW throttle shaft wouldn't fit good and snug anymore, so the original hole was drilled out and a brass bushing installed? |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
