| Ford 9N, 2N & 8N Discussion Forum |
Topic: 12 volt system
[Return to Forum]
| Author |
[Modern View]
| Gary Schones
09-19-2012 13:53:18
24.248.119.26
I used my 9n to jump my truck last weeken when I was out brush hogging. Afterwards the battery on my 9n was dead. It has been converted to 12 volt and there is not much to it but I am not sure where to start. Any help is appreciated. Thanks, Gary |
| e. r.
09-21-2012 20:01:39
12.75.111.41
Re: 12 volt system in reply to Gary Schones, 09-19-2012 13:53:18
| It is possible that when the truck started you blew the alternator on the tractor. I jumped my cousins car one time as he had a dead battery. ONce the car started he put the throttle to the floor before I got out of my truck to disconnect the cables and it blew my alternator. I didn't realize it at the time but I went to a ball game that night and I noticed that my lights were dimmer and the turn signals were working real slow. Next morning, I tried to start the truck and the battery was dead. |
| Gary Schones
09-24-2012 10:38:07
24.248.119.26
Re: 12 volt system in reply to e. r., 09-21-2012 20:01:39
| I think you may be right. Or at least it was time for it to go because I took it off and had O'Reileys test it. Yep it was bad and I got ane (rebuilt)alternater for 47.00. I got a bunch of funny readings from my volt meter on the new one and I may need to change the way they the one wire system is set up. So far it is working. Thanks for everyones help on this. |
| soundguy
09-20-2012 04:37:09
184.233.35.110
| | as others said.. check battery first.. then chack charge system. what type of alt or generator do you have? |
| Gary Schones
09-20-2012 06:57:28
24.248.119.26
Re: 12 volt system in reply to soundguy, 09-20-2012 04:37:09
| Thanks for everyone’s help on this. The 9N has an alternator on it. It was already converted when I got it 5 years ago. The battery is in it’s 3rd year and could be bad. I will start there. I noticed that the amp meter is not hooked up. I am not sure which wires would go to it. Do you have any suggestions? Thanks, Gary |
| soundguy
09-20-2012 08:32:15
173.104.45.108
Re: 12 volt system in reply to Gary Schones, 09-20-2012 06:57:28
| | the charge wire from the alt should go to a 2 post ammeter, then to the battery.. usually via the hot solenoid connection. power for the key and resistor comes off the alt side of the ammeter.. same with lamps.. no other wires on the battery side of the meter. that keeps your net charge / discharge system correct. if meter reads backwards.. swap wires side to side.. |
| Mr. T. Minnesota
09-19-2012 15:14:59
68.170.114.158
| G.S., How old is the battery? Check the voltage with no load. If it reads anything less than 12 volts you may have an internally shorted cell. Recheck all terminal connections, you may have loosened them while using cables. Hope this helps! Mr. T. Minnesota |
| Gary Schones
09-20-2012 06:58:47
24.248.119.26
Re: 12 volt system in reply to Mr. T. Minnesota, 09-19-2012 15:14:59
| Thanks for yor help. I will check it this weekend. |
| old
09-19-2012 14:30:06
209.86.226.32
| Could be just one of those things and it was time to have a problem or maybe your alternator is bad and just one of those things. I would first charge the battery and make sure it is good and holds a charge for a day or more. Then try it in the tractor and if you have a volt meter make sure your alternator is putting out around 13-14 volts. Then turn off the tractor and pull one of the battery cables off and watch for a spark when you do. If you get a spark then you have something draining the battery and time to track that down |
| Gary Schones
09-20-2012 07:00:06
24.248.119.26
Re: 12 volt system in reply to old, 09-19-2012 14:30:06
| Great advice, thanks. Gary |
| JMOR
09-19-2012 13:58:03
72.181.173.171
Re: 12 volt system in reply to TheOldHokie, 09-19-2012 13:53:18
| Quoting Removed, click Modern View to seeCharge the battery....see if it will take & hold a charge, or put another battery in it, or take battery & have it tested. After you know battery is good, there are other places to look. Come back, then. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
