Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 9N draining battery
[Return to Forum]
TOM N MS
09-15-2012 15:36:38
98.95.142.224
6 volt system-sparks when you connect/disconnect battery cables(key off)..Disconnect generator and no spark..How common is it for generators to be the drain problem? Thanks
[Reply]   [No Email]
Plane Bart
09-16-2012 14:22:51
70.8.195.152
 Re: 9N draining battery in reply to Michael priar, 09-15-2012 15:36:38
Tom I had this problem also with mine I found the stud for the single wire generator was grounding out.
Take part the generator and read continuity from the stud to the casing
I had to file off some of the solder on the back side also cleaned up the casing on the internal parts while I had it apart.
Check the field windings also they should read continuity through the windings also.
[Reply]  [No Email]
Plane Bart
09-16-2012 14:22:07
70.8.195.152
 Re: 9N draining battery in reply to John in MIch, 09-15-2012 15:36:38
[Reply]  [No Email]
Mr. T. Minnesota
09-16-2012 02:11:10
68.170.114.158
 Re: 9N draining battery in reply to TOM N MS, 09-15-2012 15:36:38
Tom,
Are there any other circuits that could cause a slow draw? On the generator track again, does the generator charge? Did you try both sides of the bridge rectifier, maybe grounded inside. I would check the amount of current being drawn, amp meter between the battery post and battery cable. Hope this helps!!
Mr. T. Minnesota
[Reply]  [No Email]
TOM N MS
09-16-2012 04:50:10
98.95.142.224
 Re: 9N draining battery in reply to Mr. T. Minnesota, 09-16-2012 02:11:10
Have not touched the rectifier since I installed it several yrs ago..Plan to go to my Dad"s today-will ck amount of draw..Thanks Note: Reason I installed the Bridge several yrs ago is that he was having draining problems-found bad cutout--bought two and they were both bad.--installed the BR and it took care of it till now..
[Reply]  [No Email]
soundguy
09-15-2012 19:34:47
173.103.255.60
bat cables spark.. but armature on genny doesnt?
i'd look for another load...
[Reply]  [No Email]
TOM N MS
09-16-2012 04:56:06
98.95.142.224
 Re: 9N draining battery in reply to soundguy, 09-15-2012 19:34:47
Not sure I understand----What I was trying to say was--battery cables don't spark while you disconnect or connect them while the one wire to the genny is disconnected.
[Reply]  [No Email]
soundguy
09-17-2012 05:01:11
173.105.207.29
 Re: 9N draining battery in reply to TOM N MS, 09-16-2012 04:56:06
well that's not exactly what you said before.
so..
lets get very specific.. this is an esy issue to trace that is being made difficult due to lack of clarity of posts.. way too much time is being wasted here.
1.
with genny arm hooked up.. do bat terminals spark when being disconnected?
if yes, put a test lamp inline to arm.. if it lights up guess what.. it's the load.. whatever cutout or diode setup you have is not working. if a diode.. is it installed backwards?
[Reply]  [No Email]
36 coupe
09-17-2012 02:31:19
66.186.169.176
Its not the generator.
[Reply]  [No Email]
Plane Bart
09-15-2012 16:45:16
184.199.70.142
I had the same problem with my six volt 9N single wire generator
the made in the land of the almost right cut out relay would arch when motor was running basically welding the contacts together and the springs were not strong enough to pull them apart.
This would put a back feed to the generator and drain the battery.
I purchased a full wave bridge rectifier 25 amp 50 volts as suggested by others on this site I plan to put it intomorrow
[Reply]  [No Email]
TOM N MS
09-15-2012 18:06:38
98.95.142.224
 Re: 9N draining battery in reply to Plane Bart, 09-15-2012 16:45:16
I put a bridge rectifier on his(My Dad"s) 2N several yrs ago-you won"t be sorry u did that.
[Reply]  [No Email]
old
09-15-2012 15:50:31
209.86.226.56
Not sure if it has a V.R. or cut out but either one will cause that problem since a generator is working as it should will motor and that in it self will cause a draw on the battery so you have a sticking relay in the cut out of V.R.
[Reply]  [No Email]
TOM N MS
09-15-2012 18:08:38
98.95.142.224
 Re: 9N draining battery in reply to old, 09-15-2012 15:50:31
Has a bridge rectifier on it-I installed several yrs ago..any other suggestions? Tks
[Reply]  [No Email]
Mr. T. Minnesota
09-15-2012 18:58:21
68.170.114.158
 Re: 9N draining battery in reply to TOM N MS, 09-15-2012 18:08:38
Tom,
I have used what I guess to be a "bridge rectifier" on my R2 Cat. I am also using a "BR" on my Wincharger generator system because I could not find a good cut out. They were about $30.00. Both systems are 6 volts.
A few days ago a forum member was having a similar problem. Some forum members were saying that the diodes could either not carry current or fry and close the circuit. Hope this helps!
Mr. T. Minnesota
[Reply]  [No Email]
TOM N MS
09-15-2012 19:09:29
98.95.142.224
 Re: 9N draining battery in reply to Mr. T. Minnesota, 09-15-2012 18:58:21
Thanks
[Reply]  [No Email]
teddy52food
09-15-2012 18:37:00
184.94.175.179
Sounds like that recifier is bad.
[Reply]  [No Email]
TOM N MS
09-15-2012 19:10:52
98.95.142.224
 Re: 9N draining battery in reply to teddy52food, 09-15-2012 18:37:00
Thanks-hope not but would be my luck..
[Reply]  [No Email]
36 coupe
09-17-2012 02:47:10
66.186.169.176
 Re: 9N draining battery in reply to TOM N MS, 09-15-2012 19:10:52
Diodes short circuit or develope reverse leakage.They are not foolproof.Better up the voltage rating.The generator has to run at a higher voltage to over come the voltage drop of the diode.35 amp bridges should be heat sinked to aluminum.Screwing it to an old cut base aint enough.Generators put out some spike voltages that destroy diodes.
[Reply]  [No Email]
Bob Harvey
09-15-2012 16:36:48
209.91.107.156
Correctamundo. Apparently there is a 'solid state' replacement for the 9N cutout - check the 'Archives' HTH
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
