I'm on day 3 of trying to get spark going on my '52 8N with a side mount distrubutor. It is all stock 6V components. I've searched and read up on everything but nothing seems to work. Was hoping someone might have some ideas here.
I just got this 8N. I also have a 51 8N with a side mount, but that one is a 12 volt conversion, so I have dealt with points and the tractor in general, just not in a 6 Volt system. Thew new '52 was running "awhile ago". I put new gas in it, ran some carb cleaner through the carb, verified gas flows into the carb, put a new charged battery in it, crossed my fingers, and hit the started button. It turned over. Next thing I did was check for spark at the plugs. Nothing, but there were pretty crusty looking and the tips looked fouled. I changed the plugs to new plugs, gapped to .025, gave the points a quick polish and set the gap at .025 for those too, tried again, no spark.
Then I took a second look at the battery and realized I had it wired up negative ground (whoops), so I turned it around and hooked it back up positive ground. Tried again, no spark at the plugs.
Then I went and got a new tractor supply 6V coil, wired it in, figuring I might have cooked the coil. Still no spark at the plugs.
Then I went and got new points and condenser, installed them, gapped points at .025. No spark.
Then I grabbed my multimeter. Verified I have 6 volts going into the coil. When I check the voltage from the battery side of the coil to the points arm I also have 6 volts. So I know I got 6 volts into the distributor.
I rewired my old coil back in for giggles. No spark.
I put the new coil back on. No spark.
I prayed. No spark.
I turned the engine over with distributor cover off so I could see the points work. They are opening. I did the same with the ignition on and have no visible spark when the points open. I re-verified that the points arm is getting 6 volts. Shouldn't I see a sparking when the points are opening? I redid this in the dark of night to see if there was even a tiny spark at the points. Nothing.
I am keeping the battery charged up every night and in between trips to the parts store.
I don't know what to try next. Any suggestions (besides converting to 12 Volt)?
I prayed. No spark.
