| Ford 9N, 2N & 8N Discussion Forum |
Topic: 53 ford golden jubilee
[Return to Forum]
| Author |
[Modern View]
| jeff tolliver
09-12-2012 19:12:51
50.121.132.58
I am having a problem keeping my battery charged what is the best way to check and see if my generator is working. I can charge my battery up and run the tractor for a couple of hours then it quits and the battery is dead and i have to recharge it. thanks. |
| Royse
09-17-2012 18:14:37
69.36.49.151
Re: 53 ford golden jubilee in reply to MarcMi, 09-12-2012 19:12:51
| Glad you got it fixed Jeff. Happy tractoring! |
| jeff tolliver
09-17-2012 15:08:49
50.121.132.58
Re: 53 ford golden jubilee in reply to jeff tolliver, 09-12-2012 19:12:51
| the problem was my voltage regulator is was bad replaced it and it works fine thanks |
| Royse
09-13-2012 19:10:26
69.36.49.151
Re: 53 ford golden jubilee in reply to GB in MT., 09-12-2012 19:12:51
| Quoting Removed, click Modern View to see
You may still want to hook a light bulb between the battery and the disconnected cable to see if there is any draw.
If there is, the lamp should light.
To test the voltage regulator, try jumpering the Battery terminal of the voltage regulator to the Armature terminal while running.
If the voltage across the battery terminals comes up when you do that you need a new voltage regulator.
If the voltage does not come up, you can do a motor test on the generator.
To do that, with the tractor off of course, take the belt off the generator
and remove the arm and fld wires.
Jumper the battery negative post to the arm and field terminals.
The generator should spin like a motor. If the generator does not spin take it in for check/repair. |
| Jubilee85 (VA)
09-13-2012 07:44:49
24.149.127.253
| | As Royce said, getcha a volt/ohm meter - Harbor Fright! is giving them away almost. Wally world has them too. 6volts sitting - 6.8 - 7 volts running if 12 volts....about 12.4 sitting - and close to 14 when running... |
| jeff tolliver
09-13-2012 17:59:31
50.121.132.58
Re: 53 ford golden jubilee in reply to Jubilee85 (VA), 09-13-2012 07:44:49
| checked it today, when it is not started has 5.98 volts then started the engine and it read 5.94. when i unhooked a cable from the battery, with everything off, there was no sparking |
| soundguy
09-13-2012 05:56:46
173.103.242.226
| 36 coupe
09-13-2012 03:11:21
66.186.169.176
| What does your ammeter indicate with engine running and shut off. |
| Royse
09-12-2012 19:18:06
69.36.49.151
Re: 53 ford golden jubilee in reply to Jeaux Bleaux, 09-12-2012 19:12:51
| Measure the voltage between the battery terminals with the tractor off.
Assuming its still 6 volt, you should get about 6.3 on a fully charged battery.
Start the tractor and measure the same place. Should get around 7.2 volts.
Post what you find to get help with narrowing it down. |
| oldtanker
09-12-2012 19:53:48
66.228.255.239
Re: 53 ford golden jubilee in reply to Royse, 09-12-2012 19:18:06
Do as Royse says.
My 1st thought is that if you are starting out with a fully charged battery, no lights on it should run a whole lot longer than a couple of hours. Before I converted my Farmall M the generator was bad. Dirtributer ignition system powered by the battery. I'd get 2 or 3 days from a fully charged 6 volt. So to add another thing, pull the battery, charge it, let it set overnight and then have it load tested. Most places will test it for free. You can check for a short by shutting every thing off....long list here, ignition switch in the off position and the lights turned off if equiped. Then disconnect a batter cable. If sparks jump as you are pulling the cable there is something drawing on the battery that shouldn't be.
Rick |
| jeff tolliver
09-12-2012 19:27:42
50.121.132.58
| ok will try it tommorrow and let you know. thanks |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
