| Ford 9N, 2N & 8N Discussion Forum |
Topic: charging system
[Return to Forum]
| Author |
[Modern View]
| Jimbo's 8n
09-12-2012 03:19:59
198.234.106.20
How can I determine if the voltage regulator or generator isnt working? The ampmeter shows a draw and the battery will wear down after about 4 hours of use. It"s a 1950 side mount 6v 8n. Thank you. |
| 36 coupe
09-13-2012 03:16:47
66.186.169.176
Re: charging system in reply to Jimbo's 8n, 09-12-2012 03:19:59
| The ammeter will tell you if the battery is being charged. |
| NOXJohn
09-12-2012 04:10:04
184.5.164.213
| Check the battery voltage before you start the tractor and again after the tractor is running. After voltage should be higher the before voltage. If not you have a problem. |
| Jimbo's 8n
09-12-2012 04:20:51
198.234.106.20
Re: charging system in reply to NOXJohn, 09-12-2012 04:10:04
| The battery voltage is lower when its running. It"s definitely not charging. Just not sure if the problem is with the voltage regulator or generator or both. |
| soundguy
09-12-2012 04:26:12
173.107.205.146
Re: charging system in reply to Jimbo's 8n, 09-12-2012 04:20:51
| | time to test it then. first, polarize the genny, jumper battery to armature with her not running.. start up and check.. any change? no? try this.. with machine running, jumper field to ground at the genny.. any change? yes? get a new vreg.. field ckt is bad. no? jumper field to ground, AND jumper bat to arm. any change? yes? get a new reg.. cutout and or field ckt is bad. no? unjumper.. shut engine down.. remove belt from gen.. jumper field to ground and bat to arm.. genny should spin. if yes, check wireing and redo above tests.. wires in harness must be damaged or hooked up wrong. if no spin.. take genny in to DR for a checkup. |
| Jimbo's 8n
09-12-2012 04:30:53
198.234.106.20
Re: charging system in reply to soundguy, 09-12-2012 04:26:12
| Thanks. Does the key have to be on to polarize the genny? |
| soundguy
09-12-2012 05:04:52
173.107.205.146
Re: charging system in reply to Jimbo's 8n, 09-12-2012 04:30:53
| | the key sends power to the ignition coil.. nothing else. why would it matter if the key was on. key has NOTHING to do with the generator or regulator. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
