| Ford 9N, 2N & 8N Discussion Forum |
Topic: 8n clutch grinding gears
[Return to Forum]
| Author |
[Modern View]
| brian456
09-09-2012 16:58:18
50.122.42.243
I recently bought a 1950 8n that runs great but when you start it cold (80degree day) it shifts perfectly but as it warms up to operating temp it will shift fine in between gears but if you put it in neutral and let the clutch out and then put the clutch back down it will not go into any gear without grinding severly but if I let it cool off a while it is fine I have experminted with the freeplay but it works best when set by the book at 3/4 inch I was just wondering if anyone has any ideas before I split it. Thank You |
| brian456
09-10-2012 04:12:01
50.122.42.243
Re: 8n clutch grinding gears in reply to brian456, 09-09-2012 16:58:18
| No I am not shifting on the move I am only shifting while stopped if you push the clutch in and stop you can change gears just fine but if you put it in neutral and say get off the tractor to do something and get back on push in the clutch and try to select a gear that is when it grinds when it is hot cold it is fine |
| soundguy
09-10-2012 06:29:33
184.245.116.112
Re: 8n clutch grinding gears in reply to brian456, 09-10-2012 04:12:01
| | got any oil drips from the bellhousing weep hole? might have an oil, grabby clutch. try this.. next time you get off and leave it in neutral, stomp the clutch and rev the engine up and down a few times and pump the pedal while doing so... then wait a second and try to shift. if it shifts.. you likely got a sticky clutch.. and may even have a clogged weep hole... |
| 1951 8N
09-09-2012 19:54:02
173.189.131.113
| Quoting Removed, click Modern View to see
The gears are not straight cut in an 8N. They are helical cut gears. It has nothing to do with the gears being straight cut or helical cut. The reason you can't shift these tractors on the go is because the transmissions are not synchronized. |
| old
09-09-2012 19:06:02
209.86.226.19
| These tractor have straight cut gears in them and are not like cars and trucks so you should not start out in 1st then go to 2nd etc you put it in the gear you want and take off in that gear. Also as the engine gets warm so does the transmission so the oil gets thinner so it takes move time for the transmission gears to stop when you push the clutch down you can not heavy them old heavy gears it takes time to slow them down plus if you idle the engine down that helps |
| HCooke
09-09-2012 18:16:18
70.195.65.16
| Are you shifting while the tractor is moving? These transmissions were designed to be shifted when completely still. Select the gear for the job at hand and go. Do not shift on the fly. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
