Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Noise from governor?
[Return to Forum]
kylemorley
09-09-2012 09:23:40
96.61.92.35
While trying to troubleshoot my 8n's reluctance to accept a load,
I notice that the governor, while passing most of the informal
tests that have been mentioned here, at the lowest setting of
the throttle lever makes a high pitched rattling noice - sort of a
she-e-e-e-e-e (never gets to the t), like a handful of birdshot
being swirled in a metal container.
At least I think it is my governor, I suppose it could be
elsewhere but seeing as how playing with the throttle makes it
come and go I am pretty sure.
Oh, I also notice that I have to open the throttle 1/3 or the way
before I can detect any increase in speed from the motor
(tractor standing stil).
Is this normal, or is my governor trying to tell me something.
[Reply]   [No Email]
Mr. T. Minnesota
09-09-2012 12:09:25
68.170.114.158
 Re: Noise from governor? in reply to kylemorley, 09-09-2012 09:23:40
Kyle,
If you need ball bearings, lower race and other rebuild parts I will send you my used parts. They came off a 1948 8N. Just rebuilt my governor to find out that the governor was ok and the carb to governor linkage was not the correct length. Bruce assisted with finding the correct linkage length. New kit costs about $80.00.
Let me know- mechanic that took the governor apart suspected linkage problem!
Mr. T. Minnesota
[Reply]  [No Email]
kylemorley
09-09-2012 12:40:58
96.61.92.35
 Re: Noise from governor? in reply to Mr. T. Minnesota, 09-09-2012 12:09:25
Thanks - you picked the right guy. One of my vices when it comes to machines is that I hate to waste new parts when servicable old parts will do, so, since it is looking like my governor is going to need attention, I'd be delighted to acquire some hand me downs.
Let me know what you want for post etc. You can email me at kylemorley66@yahoo.com.
[Reply]  [No Email]
Bruce (VA)
09-09-2012 09:33:55
24.125.80.178
" like a handful of birdshot
being swirled in a metal container."
There are marble-sized steel balls in there which will rattle like that.
" while passing most of the informal
tests that have been mentioned here,"
Such as?
" I also notice that I have to open the throttle 1/3 or the way
before I can detect any increase in speed from the motor "
Hmmmmmmm.........
Lack of low speed throttle response.
Doesn't that tell you something?
Try some of these tests..........
There are three ways to check to check the operation of the governor. Get the throttle lever at it's lowest point (engine ideling) Then, start tapping the throttle lever slowly open. How far does the throttle move before the engine speeds up? Lack of low speed throttle response (like about 1/3 of the throttle) is the classic symptom of a bad or out of adjustment governor. Next test, put it in gear at about 1/4 throttle, put your foot on both brakes & let the clutch out. The engine should throttle up as the governor arm opens the throttle plate in the carb to compensate for the load on the engine. Next test, w/ the tractor running, pull on the rod going to the carb; does the governor pull back? If that does not work, get out the I&T FO4 manual & check out the 'adjusting governor' paragraph. Finally, before I paid $200 or more for a governor, I'd pull it off & open it up. It could just need new balls & races.
[Reply]  [No Email]
kylemorley
09-09-2012 12:49:19
96.61.92.35
 Re: Noise from governor? in reply to Bruce (VA), 09-09-2012 09:33:55
The tests I did were the ones you mention - I got them from an earlier post of yours.
I originally did them a couple weeks ago and everything seemed fairly OK. However repeating them just now, I find:
- the revs don't increase till the throttle is 1/3 open
- pushing on the throttle rod makes the governor push back.
-when I let the clutch out while holding the brakes the governor does not seem to be doing much, and unless I give it gas manually (or often, even if I do) it kills the engine.
I blew out the carb one more time and checked fuel flow from the plug on the bottom of the carb, which was steady. So I think it is probably time to pull the governor.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
