| Ford 9N, 2N & 8N Discussion Forum |
Topic: starter will not turn on inital startup after restoration
[Return to Forum]
| Author |
[Modern View]
| musclenut
09-06-2012 18:58:13
64.130.169.237
My 48 8n has been in pieces for years since I started restoring it. I finally finish it today. I tried to start it and the started won"t turn. The solinoid clicks loudly when I press the starter switch. That"s it. This tractor has been converted to 12v. Where do I begin? |
| NOXJohn
09-07-2012 05:55:14
184.5.164.213
Re: starter will not turn on inital startup after restor... in reply to musclenut, 09-06-2012 18:58:13
| Before you start the tractor make sure you have oil pressure. If you start it and don't have oil pressure you will destroy the engine in a very short, like in minutes, time. I pull the plugs and spin the engine with a 12 volt battery, key off, until I get at least 3-5 pounds of oil pressure. If this does not work on the first try you may need to prime the oil pump. |
| CharnerL
09-06-2012 20:08:54
66.175.155.151
| Get your jumper cables and jump ground to starter housing. On positive, jump brass starter bolt to battery positive. Maks sure you are out of gear. If it spins properly, starter is ok and you have an electrical connection problem. |
| musclenut
09-06-2012 19:26:47
64.130.169.237
| | The battery is good. I just finished rewiring the tractor today. All wires are new nothing smaller than 12awg all connectors are crimped and soldered on. All mateing surfaces on the tractor were sanded down to bare metal before screwing down wires. Battery cables are 2awg. Now the starter grounded to the frame I'm not sure of. It's been about a year since I mounted the started. I'll check it tomorrow. Thanks! |
| Bruce (VA)
09-06-2012 19:00:25
24.125.80.178
| | " The solinoid clicks loudly when I press the starter switch." The solenoid is making a noise because of low voltage. That is likely caused by: 1. A weak battery (charge it & check it per tip # 49)) 2. Dirty grounds/connections (remove the cables & clean the connections) 3. Bad cables or incorrect sized cables (replace them - see tip # 41) 4. Bad ground between the starter & the block. (pull the starter away from the block & clean the mating area - see tip # 36) |
| oldtanker
09-06-2012 18:58:56
66.228.255.239
Re: starter will not turn on inital startup after restorati in reply to musclenut, 09-06-2012 18:58:13
| Quoting Removed, click Modern View to see
Check your connections! To include the mating surface between the starter and bell housing.
Rick |
| musclenut
09-06-2012 21:36:37
64.130.169.237
Re: starter will not turn on inital startup after restorati in reply to oldtanker, 09-06-2012 18:58:56
| I couldn't stand it. I just went out pulled the starter and discovered I had never tighten the brass grounding L braket that grounds the solinoid to the starter. Now my engine turns over. Thanks for the help! |
| 36 coupe
09-07-2012 04:07:41
66.186.169.176
Re: starter will not turn on inital startup after restorati in reply to musclenut, 09-06-2012 21:36:37
| That is not a grounding bracket.Do a study on how a starter works. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
