Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 8n not quite running perfect
[Return to Forum]
international606
09-06-2012 16:14:29
50.126.254.91
I have an 8n front mount distributer 12v with electronic ignition. It will run fine then miss maybe back fire then will recover and run fine.
It will idle good. I have a feeling that it is electrical. Has normal power under load it will just miss every now and then. I have replaced the usual trying to track it down. plugs, cap, rotor. I am starting to think it is the bushing in the distributer. Any other thoughts.
[Reply]   [No Email]
CharnerL
09-06-2012 20:18:17
66.175.155.151
 Re: 8n not quite running perfect in reply to international606, 09-06-2012 16:14:29
I don't think these Ns ran perfect 64 years ago, however, had a similar problem and found the PO had use none bradded copper wire. Replaced the plug and coil wire and it ran near perfect thereafter.
[Reply]  [No Email]
JMOR
09-06-2012 19:35:10
72.181.173.171
 Re: 8n not quite running perfect in reply to HCooke, 09-06-2012 16:14:29
Quoting Removed, click Modern View to see0.030 magnet assy to EI module is spec, but 0.010 to 0.060 is supposed to be acceptable limits....that allows for a lot of distributor bushing wear. Probably looking in wrong place for the problem at hand.
[Reply]  [No Email]
Mr. T. Minnesota
09-06-2012 18:33:14
68.170.114.158
606,
Had trouble with my 2N starting in humid weather. It was the only time is was difficult to start. Went through everything: points, plugs, carb, new distributor cap and gasket. Finally changed the bushings as Bruce and other forum members had suggested. I knew there was some play, but did not think it was the problem. It now starts and runs like a "new" 65 year old N tractor.
Hope this helps!
Mr. T. Minnesota
[Reply]  [No Email]
oldtanker
09-06-2012 17:29:01
66.228.255.239
I would also check your wiring, you may have an intermittent short. Check the switch too.
Rick
[Reply]  [No Email]
soundguy
09-06-2012 17:24:50
107.41.167.3
the local EI advocate might be along to help you with it.. though probably not. :)
really though.. quit guessing.
it's easy to see if the shaft has play. if no play.. do the regular first test you should have done in the first place.
check spark.
if spark is good.. check fuel.
heck.. I'd do a comp test and maybee pull side valve covers and see if you got a sticking valve...
post back
[Reply]  [No Email]
Bruce (VA)
09-06-2012 16:32:55
24.125.80.178
" I am starting to think it is the bushing in the distributer. "
It could be.
It's easy enough to check.
There are two, front & back.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
