Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Battery update
[Return to Forum]
Dave/MO
09-03-2012 07:44:41
173.186.176.151
I had the alt tested and it passed and charged battery and left alone for 24 hours and it went from 13.6 to 13.2. Does this mean I have a slow drain. I think I know the answer but I need a second opinion.
[Reply]   [No Email]
oldtanker
09-13-2012 09:41:26
66.228.255.239
 Re: Battery update in reply to Mad Farmer, 09-03-2012 07:44:41
I put a full charge on both deep cycle and regular starting batts. After setting several days will still read over 13 volts. Heck right now my deep cycles are readin about 12.8 and they have been setting over 2 months.
Rick
Rick
[Reply]  [No Email]
Hobo,NC
09-04-2012 05:01:50
98.17.104.143
 Re: Battery update in reply to Bruce (VA), 09-03-2012 07:44:41
NO what you reading is a surface charge ...
The surface charge must be removed from a freshly charged battery before testing. A 12 hour lapse after charging qualifies, or you may remove the surface charge with a load (20 amps for 3 plus minutes). Are crank the engine over for 15 sec. to burn off the surface charge...
http://www.chargingchargers.com/tutorials/charging.html
http://www.arttec.net/Solar_Mower/4_Electrical/Battery%20Charging.pdf
http://www.buchanan1.net/lead_acid.shtml
[Reply]  [No Email]
old
09-03-2012 08:28:40
209.86.226.40
 Re: Battery update in reply to Dave/MO, 09-03-2012 07:44:41
Sounds like you have the battery over charged. A good battery should read right around 12.3 volts give or take a tad bit. What you read on that one says it is over charged and it will in fact try to right it self over time and slowly go down to around the 12.3 volts it should be. By the way you do know you can take that battery to an auto parts store where they can load test it so you know for sure it is good
[Reply]  [No Email]
oldtanker
09-03-2012 12:21:48
66.228.255.239
 Re: Battery update in reply to old, 09-03-2012 08:28:40
old said: (quoted from post at 08:28:40 09/03/12) Sounds like you have the battery over charged. A good battery should read right around 12.3 volts give or take a tad bit. What you read on that one says it is over charged and it will in fact try to right it self over time and slowly go down to around the 12.3 volts it should be. By the way you do know you can take that battery to an auto parts store where they can load test it so you know for sure it is good
Old a fully charged 12 volt battery will read about 13.6-13.8 volts or so.
Rick
This post was edited by oldtanker at 12:22:09 09/03/12.
[Reply]  [No Email]
36 coupe
09-13-2012 05:03:21
66.186.169.176
 Re: Battery update in reply to oldtanker, 09-03-2012 12:21:48
You may see over 13 volts after an engine is shut down but the voltage will drop over time.a battery that is discharged will take on a surface charge soon after being put on a charger.If you check with a hydrometer the battery is still in a discharged state.The new chargers from China that have a lot of blinking leds will charge a battery to a half charged state and shut off.They have a US makers name on them.These new chargers do not have a transformer in them, cost little to build and dont work.A friend bought one.We found it shut off at half charge.It took 3 more hours on a 6amp charger to read full charge.
[Reply]  [No Email]
old
09-03-2012 12:39:41
209.86.226.60
I have never seen one read that high the highest I ever see is maybe 12.8 or so
[Reply]  [No Email]
Jim in Ma.
09-03-2012 08:12:50
72.70.99.83
Disconect the ground cable, Hold a light bulb (same voltage) between the ground and that batery cable. If it lights up you have a draw somewhere in the system. Good luck!
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
