Topic: Carb Backfire
[Return to Forum]
| Author |
[Modern View]
| JCinKY
09-02-2012 18:43:10
166.147.120.158
Brother dropped off his old N today and wanted some work done...guess it'll cost him a case of beer. 6v front dist unknown year. He blew a head gasket and put in a new felpro. Told me he wanted a new cam gear after I did mine and a rewire, points, dist overhaul and general tune up.
I've replaced everything I was asked of and now I've got a backfire through the carb. Bout set the dam thing on fire.
Its wired right and the head was an isolated incident. My question is, is it more likely that I've time timed cam 180 off or just too lean? |
| JCinKY
09-03-2012 14:45:12
166.147.120.155
Re: Carb Backfire in reply to JCinKY, 09-02-2012 18:43:10
| Seems I've gotten to the bottom of it...
Pulled valve covers and timing (and lash while I was in there) was correct. Did comp test again, no change. Pulled distributor and looks like I installed the "only goes one way" front dist the wrong way. :x
I noticed a small crack in the housing and when I installed the cam gear, the slot was a little wallered out. Guess it happened before. Valve timing was correct but ignition was 180 off. I'll post back when she's running and delivered. |
| horsin around
09-03-2012 07:41:14
108.215.68.41
| JC After you did this work.... Was it back firing when you were cranking on it or once you got it running ? post back |
| JCinKY
09-03-2012 12:00:37
166.147.120.148
Re: Carb Backfire in reply to horsin around, 09-03-2012 07:41:14
| Quoting Removed, click Modern View to see
It was backfiring while cranking. Tried a little ether and leaned the carb out but have not got it running. I just did a cold (obviously) compression test and got 105, 85, 85, 80 on 1-4. Guess I'll pull the valve covers for a look... |
| JCinKY
09-02-2012 19:57:36
166.147.120.144
| Cam gear only goes one way(?) four holes are offset and only line up in correct position right?
This post was edited by JCinKY at 20:00:20 09/02/12. |
| JCinKY
09-02-2012 19:35:08
166.147.120.144
| I'll check comp tomorrow after I get a little time in the deer stand. Gears went on with marks lining up every two turns of the crank. Guess it could be the wrong two turns...
Doh! |
| old
09-02-2012 19:42:19
209.86.226.27
Re: Carb Backfire in reply to JCinKY, 09-02-2012 19:35:08
| I do not think if the marks are right that it can be wrong. Crank turns 2 turns for every one turn of the cam so they have to line up right or wrong not other way. If you count the number of teeth on the crank gear and the cam gear you will find that one has twice that of the other so not way to get it wrong unless the gears are marked wrong. NOW as for the deer stand either your season starts a long time before ours does or you better not be seen by the wrong people. Here in Missouri bow season opens Sept. 15th |
| old
09-02-2012 19:27:29
209.86.226.27
| Well if your 110% sure you have the firing order right then yep could be the timing of the cam but if you lined every thing up like it should be not likely. If running lean choking it would change that and that is the easy way to see which it is |
| R Geiger
09-02-2012 19:26:32
50.39.138.117
Re: Carb Backfire in reply to Bruce (VA), 09-02-2012 18:43:10
I would do a compression check, if valve time is off you will see it. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
